Old 01-03-2016, 01:38 PM   #1
Reddaddy67
Reddaddy67's Avatar
Nilfisk E130.3-9 help with hose banjo
Hi
I've been in contact with Qwashers about making me a 15M replacement hose for my new (used once) Nilfisk E130 to rid me of the dreaded coils...
There isn't much out there for this model apart from a Nilfisk upgrade called a superflex hose.
I'm trying to confirm if the banjo within the hose reel on my washer is either straight or 90 deg?
As I've never taken one apart before I don't wish to damage it. I took a photo of what I found which shows a sleeve? Going to a 90 deg bend, what I'm unsure of is, is the banjo under the straight sleeve? Or is it the 90 degree bend?
The official Nilfisk replacement advert shows a small picture on the box with both connections being straight.
Qwashers need to know in order to make up my order.
Also, as I'm new to this, how would I remove and replace it?
Reddaddy67 is offline   Reply With Quote
Old 01-03-2016, 02:10 PM   #2
shine247
shine247's Avatar
Does this help? I seem to remember my 140 is straight.
http://www.detailingworld.co.uk/foru...d.php?t=185586
Old 01-03-2016, 02:50 PM   #3
Reddaddy67
Reddaddy67's Avatar
This helps a lot
It looks different as you've obviously removed the hose reel, it's more what I expected from mine, a pin and brass connection which I have yet to find...
the photo I took was from tracing the hose back into the reel, unscrewing a small cover plate and that's as far as I got last night apart from unsuccessfully searching for answers online.
I presume I need to take it apart now to find the Banjo itself as you can see from my photo there is no brass pin connection visible so far, it must be inside the reel housing?
Old 01-03-2016, 03:21 PM   #4
shine247
shine247's Avatar
Once you have taken the wheel off and start reassembling, put some grease on the moving parts of the wheel, it makes it easier to wind on and off. I bought the Nilfisk hose which is exceptional so if you can get it for a few pounds more, I would.
The Following User Says Thank You to shine247 For This Useful Post:
Reddaddy67 (01-03-2016)
Old 01-03-2016, 03:54 PM   #5
Reddaddy67
Reddaddy67's Avatar
http://www.ebay.co.uk/itm/Nilfisk-Su.../272151987642?
If you vouch for the quality of the Nilfisk upgrade then i'll grab one at this price as it's similar money to Qwasher but keeps my warranty valid
no coils with this then??
Old 01-03-2016, 04:30 PM   #6
shine247
shine247's Avatar
That's the one. Somewhere on the bought today thread I posted a picture of it. Kranzle's are highly thought of and these are at least as good if not better.
Old 02-03-2016, 08:25 PM   #7
Reddaddy67
Reddaddy67's Avatar
Spoke to Jim at Browns today who sell the Nilfisk upgrade hoses, although his ebay site advertisers this upgrade as suitable for my E130.3-9 X-TRA plus the E140 and P150 it will NOT fit my washer.
This is apparently due to the right hand "special" bend in the hose which I have found in my photo which sits inside the hose reel.
The other models have straight connections and different fitment. This bend sits just before the banjo as in my photo.
Jim in his experience did not think there were any possible options for a longer more supple hose😢
No replies from Qwashers for nearly 2 weeks but I doubt he would be able to replicate the same thing unless I sent him my existing one maybe?
Have also emailed Direct Hoses too so shall cross my fingers.
Looks like I've got a nice washer with a naff short hose unless I remove the hose reel maybe?
Old 08-03-2016, 11:01 AM   #8
Reddaddy67
Reddaddy67's Avatar
Contacted Nilfisk customer service and they confirm that the new brass connection within models E30.3 and E140.3 are a 90 degree bend within the hose reel.
There are no options to upgrade to a longer or more supple hose at all.
His answer was to lay the hose out in the sun to stop it coiling!
Still following up on whether the superflex hose will fit or connect if I remove the hose reel completely.
Awaiting Nilfisk to confirm.
The Following User Says Thank You to Reddaddy67 For This Useful Post:
shine247 (08-03-2016)
Old 09-03-2016, 07:23 PM   #9
Reddaddy67
Reddaddy67's Avatar
Nilfisk update
Well they were good enough to reply but not much help really😕
I asked specifically if I removed the whole hose reel if their Superflex hose connection would then be able to fit direct to the port on the machine.
No answer to this question apart from a suggestion that I could always seek out a specialist pneumatics company to make me a one off hose and connection at my cost....
But they dismissed this by quoting health and safety and suggested I be happy with it was from the factory as there are no upgrades available.
No replies still from qwashers, Browns or Direct Hoses with their views.
What a pickle all I need is a decent hose
Old 09-03-2016, 08:04 PM   #10
shine247
shine247's Avatar
That is disappointing, thank you for updating the thread.
