Hi All
I see there was a topic on bird poo etching quite recently where using a hairdryer was mentioned. I thought I'd start a new topic on this, just to highlight that it works!
The Mrs Golf had 2 bird poos on the car that had sat there for a couple of days. After washing the car, there were obvious marks left behind. I clayed the area and then took these pics:
You can see they look pretty bad.
Now, if the surface was truly etched, the only way to remove these marks would be with a polish. However, I recall reading a post on another forum that said the marks actually come from the lacquer under the bird mess expanding and contracting differently to the surrounding area, and that all that was needed was a hairdryer.
It's not a very powerful hairdryer, but I started a couple of inches away and after a few minutes not much had happened, so I took it in till the hairdryer was basically sitting on a cushion of air practically next to the surface.
Well, it didn't take long to see a significant improvement:
After a couple more minutes, it had practically gone - I could barely believe it actually worked! Although the mark is still there if you look very closely it is barely noticeable. What a result!
This seems to give credibility to the idea that the bird poo doesn't etch the surface at all - so no need to start removing lacquer with a polish. Give the hairdryer a go!
Finished off the job with a top up coat of jetseal, and the car's looking good again!
