Old 28-11-2016, 04:51 PM   #1
tbcuprat
tbcuprat's Avatar
Which DA can run 3.5" and 5" Backing pads.
Hi,
Looking to renew my DA as my Porter Cable 7242 although has been great is coming up for 9 years old.
I already have a Kestrel SIM 180 but I tend to favour the Porter.
To be honest the 110/220 transformer is a bit of a faf.
I'm looking for a DA that can comfortably fit a 4" spot pad and go up as large as 6"
Price wise I'm open to anything as I'm quite happy to write the cost off against the same number of years if it's good enough.
Things that would be good...
I'd ideally like one to be fairly quiet. I'm a bit more educated than I was back when I got it (lack of ear defenders). As a result I now have tinnitus.
Vibration dampening would also be quite important.
I'd also like something with a long lead.
Something thats ergonomic.
But the main thing is 4" and 6" pads is mandatory.
Any suggestions?
tbcuprat is offline   Reply With Quote
Old 28-11-2016, 06:36 PM   #2
fozzy
DW Reviewer
fozzy's Avatar
Das 6 pro, the pro plus has a 15mm throw and won't go any smaller than a 5" backing plate. The new Vertool Force drive may be a good option as that only has a 8mm throw so should take a spot pad easily.
fozzy is offline   Reply With Quote
Old 29-11-2016, 12:15 PM   #3
tbcuprat
tbcuprat's Avatar
I'm reading that LC Backing plates are compatible with Vertool and Flex.
Anyone tried the Vertool LC backing plate combo on a 4" spot pad yet?
The Following User Says Thank You to tbcuprat For This Useful Post:
ammo-mcr (12-12-2016)
Old 17-01-2017, 06:40 PM   #4
Reddaddy67
Reddaddy67's Avatar
Has anyone found this out ? Maybe intetested in the Vertool Forcedrive IF it will take a spot pad backing plate and safely use it.
Sent from my LG-H850 using Tapatalk
Reddaddy67 is offline   Reply With Quote
Old 17-01-2017, 07:00 PM   #5
Hereisphilly
Hereisphilly's Avatar
The 3401 will do 100mm pads with the lc backplate system
I know because I have one
If the vertool is an exact carbon copy of the 3401 then there's no reason why it can't too
Sent from my XT1635-02 using Tapatalk
Old 17-01-2017, 07:01 PM   #6
Hereisphilly
Oh and the normal das 6 pro will do it too
Reddaddy67 (21-01-2017)
Old 17-01-2017, 07:02 PM   #7
tbcuprat
tbcuprat's Avatar
It's been stated on a Facebook feed that the two the drive mechanism is different between Vertool and flex.
Old 17-01-2017, 07:06 PM   #8
Hereisphilly
Oh yeah, slightly different teeth apparently
https://m.facebook.com/pg/Vertool-10...58040440957410
Old 17-01-2017, 07:45 PM   #9
Your better off with the Flex 3401 and like said before you can use the 100mm HT pads.
Old 19-01-2017, 07:58 PM   #10
Deje
Rumors say it will be a copy of LC backing plate system for the Flex 3401 copy, might not suit all Flex 3401 copies.
