Go Back   Detailing World > Detailing Products > The Official DetailingWorld™ Review Section > Tools / Towels / Other
Old 09-12-2016, 11:13 AM   #1
Johnnyopolis
ADMIN
Johnnyopolis's Avatar
Detailingworld™ Review – Pure Final Rinse
I just want to say firstly a massive thank you to Jay from Pure Final Rinse for giving me the opportunity to try this product out on behalf of DW.
To see more on Pure Final Rinse you can check the website - https://purefinalrinse.co.uk/
The Product:
The product arrived in a sturdy box complete with all the connections needed to get up and running, I was sent the ‘single bag’ version. The product is also available with a 2 bag option and 4 bag option for heavier users. I was looking forward to trying this product as I have used in the past a number of pure water solutions ranging from the what I like to call the divers tank with resin in through to a 4 stage filtration RO unit which uses ALOT of water.
This product also interested me as it had a built in TDS meter so I didn't need to keep testing the water just hook it up, turn it on and hit the button on top to see the TDS reading.
Once hooked up I initially tried a test, switched the water on ran it through the system and then pressed the TDS meter button. At first, I was a little disappointed as I found that the TDS had dropped from 330 ppm down to 30ppm I know this looks amazing but I was hoping for Zero. BUT, I then experimented with pressure and lowered the pressure a little and managed to get it down to 1ppm! That I was happy with and have now maintained that through about 8 or 9 cars I have tested with.
One other great feature of this product is the bag changing process of the resin. Simply open it up remove the bag in one and replace with a new bag. No resin anywhere and so simple. This is a lot easier than the diver's tank style of the bottle I have used in the past.
The Single Bag Vessel that I have tested retails for £199.00 There is also a double and quad bag which retail at £329.99 and £499.99 respectively. The replacement resin bags are £29.99 for the single unit up to £99.99 for the quad unit. I believe there will be a group buy on these soon.
Conclusion:
The Pure Final Rinse is a great all round system for anyone looking for a filtered water system. In the winter you could rinse the car off and leave it and go in and warm up! In the summer you can use it to prevent water spotting and ease the drying process on a hot day. I will be buying one as I find the process of hooking it up and using it simple, the carry handle makes it easy to move. The only stumbling block I could see is the price of the initial unit, but for a unit which comes with resin and a built in TDS meter, I believe this is a worthy investment.
“DW has followed the Manufacturer’s Instructions and accepts no responsibility for any circumstances arising from any member using these products or following this test. “
Johnnyopolis is offline   Reply With Quote
The Following 20 Users Say Thank You to Johnnyopolis For This Useful Post:
bigkahunaburger (31-12-2016), Brian1612 (09-12-2016), Chris Dyson (10-12-2016), Daniel Branco (09-12-2016), Danny B (01-08-2017), forge197 (10-12-2016), ganwilliams (09-12-2016), Hacker (11-12-2016), JonnyG (12-02-2017), Libs (09-12-2016), marc147 (09-12-2016), Mpv2k3 (09-12-2016), onks (09-01-2017), Schizophonic (16-06-2017), shane_ctr (09-12-2016), Short1e (15-12-2016), Simonrev (09-12-2016), Smanderson117 (09-12-2016), tictap (09-12-2016), todds (05-04-2017)
Old 09-12-2016, 12:33 PM   #2
WHIZZER
T-Cut King (admin)
WHIZZER's Avatar
great review
