Old 11-01-2017, 05:42 PM   #1
CockneyPlayboy
CockneyPlayboy's Avatar
Toss up between these two ROTARY POLISHERS....
Have been looking at these two bits of kit... both seem to have good reviews (a bit of moaning at the higher speed start on the dodo..... what are your opinions and experiences??
http://www.cleanyourcar.co.uk/polish.../prod_854.html
http://www.cleanyourcar.co.uk/machin.../prod_806.html
CockneyPlayboy is offline   Reply With Quote
Old 11-01-2017, 06:55 PM   #2
realist
I've got the ep801, it's a very good machine for the money, can't comment on the other one.
realist is offline   Reply With Quote
Old 12-01-2017, 11:26 AM   #3
A&J
A&J's Avatar
I havent used any of the two, but I would choose the EP801 due to the lower start up speed (700 RPM).
Old 12-01-2017, 01:46 PM   #4
CockneyPlayboy
Cheers guys, any more for any more??
Old 12-01-2017, 09:07 PM   #5
lowejackson
lowejackson's Avatar
Not tried either machine but going from only the specs I would say the EP801 seems to be better as it has a lower minimum speed (as A&J highlighted) and a upgraded backing plate. It is not easy to tell from the pictures but the Dodo machine seems to have the standard thin backing plate which is not that useful. Unlike a DA, a backing plate makes a big difference and will cost £20-30 so if the EP801 has one then you have just saved a few quid.
If budget is not a problem then get the 3M one, it is very good as are the 3M pads. They are not cheap and feel as if they will be too soft but are perfectly matched to a rotary but not so great with a DA
CockneyPlayboy (13-01-2017)
Old 12-01-2017, 09:41 PM   #6
cleslie
cleslie's Avatar
I've had the Spindoctor (version 1) for a few years now. It's light weight and I find the digital speed display very useful. I don't find the start speed an issue at all. I like the look of the version 2. Either of the rotaries on your shortlist will do the job so go for the lightest. Weight makes the biggest difference.
The Following User Says Thank You to cleslie For This Useful Post:
Old 13-01-2017, 01:22 PM   #7
CockneyPlayboy
Thanks for the input guys!
