Old 12-07-2017, 05:27 PM   #11
Before you start adding filters (which will reduce flow) you need to be sure the length of hose you are intending to use will deliver sufficient flow. Running a PW on insufficient flow will do far more harm than a tiny amount of muck in the water.
Old 12-07-2017, 07:21 PM   #12
LeeH
LeeH's Avatar
Advise on my waterbutt setup
Solids in the pump will quickly destroy it.
You must use a filter using 'dirty' water.
If your washer is designed for static water you have nothing to worry about.
https://www.ebay.co.uk/itm/122584306104
Old 12-07-2017, 07:42 PM   #13
wax-planet
DW Sponsor
wax-planet's Avatar
i have a 210 ltr one here free to a good home if anyone wants to collect from rotherham south yorkshire
wax-planet is offline   Reply With Quote
Old 13-07-2017, 09:50 AM   #14
Schizophonic
Send a message via MSN to Schizophonic
Noted, I have tested last night with my PW and from the waterbutt it comes out at a decent flow rate, the PW kept the water output strong and worked fine. I will see what options I have for filters.
However when I attached it to my garden hozelock water extension hose which loops around, I found it didn't get enough pressure and its making me think two options
1) Get a separate extension hose and leave that trailing in the garden when I want to use the rainwater
or
2) Invest in a water pump to use with my existing extension hose to help with flow.
Back in the day when I had access to a commercial style Katcher PW, It had that filter but does it actually do anything?
Schizophonic is offline   Reply With Quote
Old 13-07-2017, 10:31 AM   #15
A "normal" garden hose needs mains pressure to provide enough flow to a PW if you're talking about any significant length of hose.
The water out of a water butt (especially if it is eg half full) is at much lower pressure - you either need to compensate for this by using a shorter and larger ID hose, or increasing the pressure with a pump. The pump is probably the better bet unless you will mostly be using the PW close to the water butt.
