Old 31-08-2017, 12:41 PM   #11
Smanderson117
Originally Posted by Cookies View Post
It looks like Tardis has been left on. If you can't get the grilles sorted, you'll be able to pick up a new set on eBay for around 20 quid.
Hope you get sorted.
Cooks
Perfect time to upgrade to black grilles
Smanderson117 is offline   Reply With Quote
The Following User Says Thank You to Smanderson117 For This Useful Post:
Cookies (31-08-2017)
Old 31-08-2017, 01:22 PM   #12
GleemSpray
GleemSpray's Avatar
IF ... and i do mean IF ..... you reach a point where nothing works, all hope is lost and you have resigned yourself to buying replacement parts ....
.... then its always worth trying exactly the same chemical (if you can figure out what caused it in the first place ) as that will sometimes loosen and lift stains that it has itself caused.
Old 31-08-2017, 01:29 PM   #13
TonyHill
TonyHill's Avatar
Would Solution Finish re-colour the black grills..? Just a thought
Old 05-09-2017, 07:44 PM   #14
mattr8700
mattr8700's Avatar
It was TFR left too long that caused the damage I think.
Certainly learnt a lesson there.
They haven't come up as bad as I anticipated, tried just about everything under the sun and a combination of some metal polish and tcut removed the worse of it. I still need to get behind them and have a clean and right at the bottom but they look better now.
mattr8700 is offline   Reply With Quote
Old 05-09-2017, 08:07 PM   #15
Njs71
Njs71's Avatar
Looking a hell of a lot better than it did do. Good job done there
Njs71 is offline   Reply With Quote
Old 15-09-2017, 06:09 AM   #16
kevin69
Do you go to the £5 hand wash dudes??
Looks like that acid stuff they use that makes all the black rubber bits go grey - and if left on too long in hot weather or warm engine, then it's pretty much baked on
kevin69 is offline   Reply With Quote
Old 15-09-2017, 06:55 AM   #17
fatdazza
What TFR? What dilution? and was it allowed to dry in the sun?
Old 08-10-2017, 07:28 AM   #18
martec06
stuff like bead juice can do the same if they dry up.
Sendt fra min EVA-L09 med Tapatalk
martec06 is offline   Reply With Quote
