Old 31-12-2017, 10:05 PM   #101
Rob D 88
Mrs got me the full set from QWashers including the stainless quick release. She also ordered a 10 metre hose with the quick release.
Used it yesterday and it is without doubt well worth the money and makes it so much easier and more enjoyable to use! I recommend to anyone thinking about getting one!
Sent from my SM-N950F using Tapatalk
The Following 2 Users Say Thank You to Rob D 88 For This Useful Post:
Soapybubbles (01-01-2018), steelghost (31-12-2017)
Old 01-01-2018, 12:53 AM   #102
Deje
I do not see if it has been mentioned in the thread, but it may be good to know that Matt Moreman uses the NPT thread in his system, which can be a bit difficult to compliment or replace parts for those living in Europe.
The Following User Says Thank You to Deje For This Useful Post:
steelghost (01-01-2018)
Old 01-01-2018, 08:45 AM   #103
It's a good point - all the stuff sold in UK and Europe is a combination of metric and BSP threads.
Although curiously, if you buy a lance with a fixed nozzle (ie one that is screwed in rather than using a QR), that will very probably have an NPT thread!
Of course the full kit from OG will work as a unit, and the quick connections are compatible with those sold here. But if you had a problem with one of the female QRs, sourcing an NPT thread replacement would be tricky in the UK.
Rob, I suspect this is one other reason why getting your setup from Qwashers rather than OG was the right call
Edit: further reading on BSP Vs NPT https://www.ralstoninst.com/news/sto...and-bspt-seals
steelghost is online now   Reply With Quote
Rob D 88 (01-01-2018)
Old 01-01-2018, 09:18 AM   #104
Deje
I like Karcher fittings
K Series Bayonet, it works better with foam lance and washer lance, quick couplings on them become a bit unstable.
But I would also like to connect and disconnect a quick connection nozzle, so my solution has become a little different.
However, I can use both Karcher attachments and equipment with fast couplings with the same trigger gun.
Old 01-01-2018, 12:33 PM   #105
I like the "Kew" quick release connections for lances - even when not under pressure they are mechanically very solid. Then I have the little 11.6mm quick connects to change nozzles.
Old 01-01-2018, 05:28 PM   #106
Deje
Yes, that's how I do, but with Karcher quick release connections, it felt wrong to not be abel to use Karchers accessories with the "Matt Moremans" system, so I wanted the best of both worlds.
The Following 2 Users Say Thank You to Deje For This Useful Post:
Rob D 88 (01-01-2018), steelghost (01-01-2018)
Old 01-01-2018, 07:34 PM   #107
Rob D 88
[QUOTE=steelghost;
It actually wasn't SG... I did not know that!
But it just made more sense, a lot cheaper and according to Damian at Qwashers the Mosmatic gun is a lower grade Suttner gun than the one Damian uses just with Mosmatic plastic covers. Everything else is pretty much identical for £100 less due to the postage fee's and I have a piece of mind that it will be easy to return if anything goess wrong or any problems.
Damian at QWashers was very helpful and if anyone is thinking about getting this setup I strongly recommend it.
Old 01-01-2018, 07:49 PM   #108
Hehe, it's definitely a good reason even if you didn't know it at the time!
Plus as you say you have a warranty contact in the UK in case of any issues, not that I expect you'll need it, that setup is pretty much as good as it gets
Old 01-01-2018, 10:18 PM   #109
Soapybubbles
Soapybubbles's Avatar
Just ordered this set up from Damian at qwashers
1 x Karcher gun inlet female quick release £9.95
1 x 22mm male x 3/8 male £1.48
1 x trigger st1100 with swivel £22.66
1 x lance with bend stainless steel £12.50
1 x mini female quick release £3.74
1 x jet with mini 4003 £8.06
1 x mini female x 1/4 male £4.72
1 x mini male x 1/4 female £1.08
1 x postage £9.00
Total £74.27
Looking forward to setting it up when it arrives
The Following 3 Users Say Thank You to Soapybubbles For This Useful Post:
dave-g (03-01-2018), Rob D 88 (02-01-2018), steelghost (02-01-2018)
Old 03-01-2018, 09:43 PM   #110
dave-g
dave-g's Avatar
I might have a look into this myself!
dave-g is offline   Reply With Quote
The Following User Says Thank You to dave-g For This Useful Post:
Rob D 88 (03-01-2018)
