Old 24-11-2017, 07:06 PM   #1
victor95
Wet sanded headlights..
So I wet sanded my Astra H headlights which have 127k miles on them.
Used the 400 grade wet and dry and sanded to the point they went cloudy.
Proceeded to DA with a white pad and Menz 2500. I’m gettin a clear finish but there’s still a lot of fine sanding marks. Tried refining with a orange pad and menz 3000.
Done a couple passes and even re sanded but still can’t get rid of them all in the light.
Any pointers?
victor95 is offline   Reply With Quote
Old 24-11-2017, 07:13 PM   #2
Andy from Sandy
Andy from Sandy's Avatar
If you went at the headlamps with 400 then I would say that needs refining with 800 then 1200 then 2500 then get the polish and DA out.
400 is very course and the different grades of paper I suggest will take care of the coarseness of the previous grade.
The Following User Says Thank You to Andy from Sandy For This Useful Post:
victor95 (24-11-2017)
Old 24-11-2017, 07:34 PM   #3
91davidw
91davidw's Avatar
Little guide I wrote about restoring headlights.
http://www.detailingworld.co.uk/foru...d.php?t=400422
Think you'll have to resand the headlights with 2500 or 3000 wet and dry before machining to remove the 400 sanding marks.
David
91davidw is offline   Reply With Quote
The Following 3 Users Say Thank You to 91davidw For This Useful Post:
RomanDan (02-12-2017), Stu Mac (24-11-2017), victor95 (24-11-2017)
Old 24-11-2017, 08:13 PM   #4
Slammedorion
Slammedorion's Avatar
Try some 800 - 2000 before the 3000
2500-3000 won’t be touching the 400 sanding marks
Slammedorion is offline   Reply With Quote
Old 24-11-2017, 08:30 PM   #5
Any pointers?
Did you do any research before you tackled them with 400 grade bud.
DimitriUK (15-12-2017)
Old 24-11-2017, 09:46 PM   #6
victor95
Thanks for all you helpful replies. Will do as you all say and report back over the weekend.
Chongo - i did quickly but admittedly I saw 400 grade and cracked on impatiently. I Just missed the step of refining it seems but that’s easy enough to resolve.
The Following User Says Thank You to victor95 For This Useful Post:
chongo (26-11-2017)
Old 24-11-2017, 09:47 PM   #7
victor95
Great guide 91davidw
91davidw (25-11-2017)
Old 26-11-2017, 02:56 PM   #8
victor95
So I went through the grades 800, 1200, 2500 and polished with Menz 3000 but I still have a lot of faint sanding marks. Whereas before I only had the odd few.
I resanded with the 2500 grit a re polished but I can’t shift them.
Hopefully pics show what I mean. From a distance the look clear n shiny but up close they not.
Obviously I’m either not sanded enough or not polishing enough but whatever I try doesn’t seem to improve.
File Type: jpg EB093C92-000D-4359-A281-92B60AF1FA50.jpg (20.8 KB, 82 views)
Old 26-11-2017, 03:06 PM   #9
dchapman88
dchapman88's Avatar
Is there any particular reason why your using Menz 3500??
After sanding i normally like to use a more aggressive polish/compound and then refine further with a finishing polish
So maybe the 2500 just aren't being polished out
Have you got anything more aggressive to use and then refine after?
Old 26-11-2017, 06:50 PM   #10
JamesRS5
JamesRS5's Avatar
Those marks will be the remains of your 400 grit attack and won’t budge until you repeat the whole sequence working your way up the papers from 800 again. Just keep working at them, they will budge eventually.
JamesRS5 is offline   Reply With Quote
The Following User Says Thank You to JamesRS5 For This Useful Post:
