Go Back   Detailing World > Newbies, Rules & Announcements > The Daily News Zone
The Daily News Zone Want to keep up with whats happening in the Automotive industry - Check back here daily.
Old 05-12-2017, 10:24 AM   #1
WHIZZER
T-Cut King (admin)
WHIZZER's Avatar
Car News - 650-HP Lamborghini Urus
Forget what you thought “SUV” meant. It’s time to welcome the world’s first “Super Sports Utility Vehicle.”
Mention the Lamborghini V12 engine to a group of car enthusiasts, and you will likely get a myriad of replies ranging from the soundtrack of this engine in the orange Miura in The Italian Job movie, to the fact that a highly developed version of the same basic motor is still used in today’s Aventador S. Less people will tell you that this iconic V12 motor is versatile enough to have powered sleek hulls to podium places in offshore powerboat racing, and was also the motive power behind the tough looking LM002 off-roader of the 1970s.
The LM002’s distinctly military bearing comes from the fact that it was originally developed for that use, but the contract was cancelled. Rather than waste all that work, Lamborghini decided to release a civilian version for wealthy people who wanted to make a very big statement.
It would probably not be wrong to say that many year later this line of thinking might even have given Arnold Schwarzenegger the idea of converting a US Army surplus Hummer H1 for civilian use. Fast forward to December 2017 and the second Lamborghini 4x4 is nothing like its spiritual ancestor.
Long and relatively low for an SUV, with plenty of the disruptive angular lines that form Lamborghini’s signature styling cues, welcome the URUS, the world’s first Super Sports Utility Vehicle, or SSUV as Lamborghini are calling it. Maurizio Reggiani, Lamborghini’s R&D Director explained that the main difficulty his team faced with the whole concept was the height and weight of this vehicle type, which is at odds with the super sports cars the Sant’Agata-based company normally produce. “An SUV is so different a vehicle from anything we have made in recent years, but we knew that the final result must be steeped in the Lamborghini DNA and so be fast and good to drive,” he says
At the same time, as it is the first ever practical family car made by us, it had to be comfortable over distance.” While 4WD is no stranger to Lamborghini, being part and parcel of both the Huracán and Aventador specifications, the range of talent of the system for the Urus had to be very much broader. In the end this encompasses settings for sand, and low grip surfaces like snow and ice as well as the normal use of all-wheel-drive to enhance grip in high performance driving on road and track. The engineers took their usual spiders web diagrams, looked at where the respective charts for the top level SUVs and super sports cars overlapped, and then extended the brief from there.
The result is a very imposing and head turning design that looks spectacular in yellow, classy in metallic blue, and rather understated in grey. The first front-engined Lamborghini since the LM002 and the Espada, its nose treatment with big air intakes both mirrors the shape of the Aventador nose at bonnet level, while showing just how much cooling air the powerful twin-turbo V8 motor requires. Even if you strip away the styling lines you are still left with a dashing form that mimics a wild animal with muscular rear haunches that looks ready to spring into action.
The rear treatment is arguably a bit fussy, but the designers have a done a good job in minimizing the visual bulk of the rear by giving the underbody diffuser a silver finish that matches the four exhaust tail-pipes. “The heart of every Lamborghini is its engine,” Maurizio explained. “In this case we needed a lot of torque to move the car effortlessly on and off-road, so there was no way our high revving V10 or V12 sports car motors could be adapted. The first ever turbocharged motor in the history of Lamborghini, the Audi derived 4.0 liter bi-turbo V8 is specifically tuned for the Urus and delivers 650 hp, with 480 lb ft (650 Nm) of torque.” That incidentally, gives it a specific output of 162.5 hp per liter.
For maximum smoothness and tractability in everyday use this powerhouse motor sends its output to all four wheels through an eight-speed torque convertor automatic gearbox. The 4WD system uses a centre torque-sensing differential, and handling is enhanced with an electronically controlled torque vectoring system that sends power to the axle and wheels with the best traction. “To guarantee maximum comfort and ground clearance over all terrain and speed variations air suspension was the logical choice,” Maurizio continued. “This gives us the ability to drop the ride height at speed for best handling and aerodynamic efficiency on road or track, and raise the ride height for off-road use where necessary.”
The other chassis trick that Lamborghini has embraced as seen by the Aventador S and now the Urus, is rear-wheel-steering. In this case, the Urus, which already has a long wheelbase for good interior space and stability gains low speed agility with an effective shortening of 50 cm in low speed maneuvers, and gains extra stability at speed through an effective lengthening of its wheelbase by the same amount. A car of this size and image needs big wheels, and Lamborghini developed the Urus with 21-inch diameter wheels in mind as the standard footwear. The factory option of up to 23-inch wheels should keep the SoCal boys happy.
The ceramic brakes behind those big wheels are equally impressive. The largest brakes ever to grace a production car, these huge vented discs measure 440 mm in front and 370 mm at the rear. And the brakes need to be large because the Urus is a seriously quick car. The stopwatch numbers the factory quotes are 0-62 mph in 3.6 sec and 0-124 mph in 12.8 sec with a top speed of 191 mph, making it the fastest production SUV. Thanks to its long and low roofline the cabin of the Urus is best described as cozy. The driving position is excellent, with the adjustable steering column and electric seats allowing most people to quickly find the ideal driving position.
On that score, the brand new factory where the Urus is built took 18 months to build and covers 80,000 square meters. We were told that it has the capacity to produce up to 3,000 cars a year, a number that Lamborghini hopes will be made up of both existing Lamborghini owners and many conquest sales.
source http://www.carbuzz.com/news/2017/12/...Level-7742306/
The Following 5 Users Say Thank You to WHIZZER For This Useful Post:
Brian1612 (05-12-2017), JR1982 (05-12-2017), SBM (05-12-2017), Soul boy 68 (05-12-2017), stonejedi (05-12-2017)
Old 05-12-2017, 10:33 AM   #2
Brian1612
Doesn't look mental enough to be a Lambo. It is one of the best looking SUVs on the market but that isn't saying much.
Old 05-12-2017, 11:20 AM   #3
Soul boy 68
Soul boy 68's Avatar
A good first effort from Lambo, I don't think they had much choice but to manufacture one as the SUV market has really taken off.
Old 05-12-2017, 11:33 AM   #4
weedougall78
weedougall78's Avatar
Looks like one of those that I don't like at first but over time it grows on me, like the BMW X6 did.
weedougall78 is offline   Reply With Quote
Old 05-12-2017, 11:35 AM   #5
Kerr
That's ugly.
Kerr is offline   Reply With Quote
Old 05-12-2017, 11:39 AM   #6
Cookies
Cookies's Avatar
The next thing you'll see is them making tractors.....
Old 05-12-2017, 12:43 PM   #7
pxr5
pxr5's Avatar
Ugly and pointless, leave SUVs to the grown ups lol. It will still turn heads though.
I understand why these companies feel they have to jump on the bandwagon, but I really wish they wouldn't. Lamborghini's conjure up something amazing - not an SUV I'm afraid.
Old 05-12-2017, 12:51 PM   #8
Kerr
This was the previous Lambo 4x4/suv. I'm sure younger people won't realise done one before, or made tractors.
The Following User Says Thank You to Kerr For This Useful Post:
Old 05-12-2017, 01:10 PM   #9
ollienoclue
Love it.
Anyone who says they would rather drive a Bentley SUV over this is mad.
ollienoclue is offline   Reply With Quote
Old 05-12-2017, 04:59 PM   #10
TonyHill
TonyHill's Avatar
Can't see the point in having something so big and so fast. If you want a supercar.....BUY a supercar
urus
