Go Back   Detailing World > Detailing Products > The Official DetailingWorld™ Review Section > Tools / Towels / Other
Old 20-12-2017, 06:09 PM   #1
voon
voon's Avatar
Question Battery impact wrench confusion
Asking this here, because it's not per se a "Detailing Tool". I'd like to get one of these 18V machines for easy wheel changes ... but they come in confusing amounts. I've seen enough videos now to get an idea of what's quality and what's not ... but I'm a bit confused by the newtonmeters of torque.
If I look into the cars manual it says, I should use about 100 - 130 Nm on the wheel nuts. But I've not seen many impact wrenches. If I look at something like a Makita DTW285, it has three settings 80 / 175 / 280 Nm (many have just 1). None of that is usable for 100-130 Nm ... but yet, many people use these things to do their wheels. I don't get it. Do they use 80 and do the rest with a manual torque wrench? Or is there some magic behind it I don't get where you can set it to 175 and then somehow "not over do it" or so?
Old 20-12-2017, 06:49 PM   #2
Alan W
Alan W's Avatar
I would suggest you use the impact wrench to do the initial tightening to a lesser torque and then finish with a manual torque wrench as you've noted.
A quality manual torque wrench will be more reliable and accurate in the long term.
Alan W
The Following 2 Users Say Thank You to Alan W For This Useful Post:
Simz (20-12-2017), voon (20-12-2017)
Old 20-12-2017, 07:07 PM   #3
Deje
You need something like this, can not the English terme unfortunately.
http://www.biltema.se/sv/Bil---MC/Ve...st-2000028488/
The Following User Says Thank You to Deje For This Useful Post:
voon (20-12-2017)
Old 20-12-2017, 07:19 PM   #4
voon
voon's Avatar
Oh, that looks interesting ... thanks
Old 20-12-2017, 07:30 PM   #5
DLGWRX02
DLGWRX02's Avatar
I understand if it’s specifically a cordless one your after, but I have one of these
https://www.machinemart.co.uk/p/cir1...rench-kit-12v/
And use it for undoing and tightening and then finish of with a torque wrench, never a good idea to rely on the impact gun for final tightening.
Old 20-12-2017, 07:42 PM   #6
Deje
Trust me, you need a machine with more torque than 170nm to loosen the nuts,my machine has 450 nm and it struggling at times to loosen the nuts and I pull (tightening) my nuts with 135nm (excuse my French)
Beemerjohn (20-12-2017)
Old 20-12-2017, 09:06 PM   #7
Moet1974
You will find many automotive guides to torque settings are very similar as it has a direct correlation to the size of the bolt you are either loosening or tightening. For general car use 100-150Nm is the rule. A Makita DTW285 would be fine for cars I have this and a DTW251. For bigger jobs DTW1001 will loosen about any nut I’ve seen. The impacts really help in loosening nuts and do play a part in tightening. Always use a quality torque wrench to calibrate the final tightness. I would also add good quality thin impact sockets are equally important. Thin is good as some standard ones don’t like to fit in alloy recesses. Never use standard non impact sockets as they can at least fracture and at worse shatter possibly causing you or the car bad damage bud.
Old 20-12-2017, 09:19 PM   #8
JoeyJoeJo
JoeyJoeJo's Avatar
I see a lot of impact drivers being marketed as suitable for "light automotive", would they be sufficient for casual wheel changes?
Not looking at getting one, just a question.
JoeyJoeJo is offline   Reply With Quote
Old 20-12-2017, 09:54 PM   #9
stangalang
king of the flexonian
stangalang's Avatar
Unfortunately no most garages will just fire a wheel in at whatever the gun goes to, which is usually WAY more than required. Best way is to use the lower setting and then finish it with a manual wrench to be sure. The guns are good for removal though and a lot quicker to mount them back initially
Old 20-12-2017, 11:56 PM   #10
Christian6984
Christian6984's Avatar
I don't own one but have a relative that has an impact wrench, there not cheap and I'm not sure which one it is but i do find myself wanting one, never had any problem removing wheel nuts that i cant even remove with other wheel braces. The one they have has two settings the softer setting can do up nuts and allow you to do the final correct torque.
https://www.milwaukeetool.com/power-...rdless/2767-20
https://www.milwaukeetool.com/power-...rdless/2763-22
impact wrench, makita
