Old 28-12-2017, 05:00 PM   #1
BaileyA3
BaileyA3's Avatar
Pressure washer lance
Afternoon all, I'm looking to buy a new lance for my vax vpw1 1700w and need some advice on nozzle sizes. The pressure washer is rated 130 bar with a 6l/minute flow rate, on a chart I found it shows I need a 025 nozzle but the lance I've found comes with 020 or 030 nozzles.
I'm worried if I go with a 020 it will cause problems with the pump with the nozzle being to small and if I go with the 030 I will lose pressure. Has anyone got any suggestions to what would be best? Any help would be massively appreciated.
Old 28-12-2017, 05:28 PM   #2
You are right to hesitate, getting the right nozzle size is vital.
If they won't supply a 025 nozzle, get the right size of nozzle elsewhere, or simply go for a different lance.
Edit: What lance is it - it's unlikely to be unique, whatever it is. Have you asked the vendor if they can supply an 025, even if not listed?
Old 28-12-2017, 07:03 PM   #3
BaileyA3
BaileyA3's Avatar
Thanks for the reply. Yes I messaged the seller asking if they do the 025 but haven't heard anything yet. Just thought I'd ask on here to see if it would be a problem as I could get 20% off eBay items until 6pm.
I don't think it's a branded Lance, just an extended one from demon motorsport on ebay. It's a 90cm bent Lance with a 40 degree spray pattern.
Old 29-12-2017, 11:21 AM   #4
Just buy the bits and make it yourself
Pipe
M22 fitting
Nozzle protector
Nozzle (choose your preferred spray angle and size)
Maybe a spot of threadlock to hold it all together (or you can use PTFE tape).
