Old 30-12-2017, 02:53 PM   #1
mawallace
Bilt Humber Snow foam - diluation
Played with the pressure washer today.
Setup
Bilt Humber snow foam in snow lance - used 300ml - filled the rest up to 1 litre.
I have an Autobrite snow foam lance and Nifisk C130.
I turned the knob on the top of the lance down to the bottom - and then back up one turn.
It gave me a snowy solution but the dirt on the car did not seem to be shifted in much of a way when I pressure wash rinsed.
Does anyone have any advice - I used half of the lance solution on one car - does this seem to be too much? Do I need to open the lance even further?
Old 30-12-2017, 03:05 PM   #2
macca666
macca666's Avatar
Have a read of this its a good review and explains about dilution rates.
http://www.detailingworld.co.uk/foru...d.php?t=400543
You don't say how long you left it to dwell which may be part to blame? most people find the cleaning power of BH excellent however it doesn't produce a thick foam.
Old 30-12-2017, 04:00 PM   #3
Beemerjohn
Beemerjohn's Avatar
You need to work out the ratio of your pressure washer setup, a quick search will show you how to do that. 4-5% at the panel is what you Autofoam
1%=70ml 430ml water 1:6
2%=140ml 360ml water 1:2.5
3%=210ml 290ml water 1:1.4
4%= 280ml 220ml water 1:0.8
5%= 350ml 150ml water 1:0.4
Are the ratios I use.
John.
Beemerjohn is offline   Reply With Quote
Old 30-12-2017, 04:17 PM   #4
Beemerjohn
Beemerjohn's Avatar
The above was calculated for a c120, so a quick comparison with my figures puts you in the region of 2% at the panel, obviously this is a rough guess.
Old 30-12-2017, 04:23 PM   #5
mawallace
Looks like I need to 'double' the solution then !
Old 30-12-2017, 04:23 PM   #6
Robbi Hong Kong
Robbi Hong Kong's Avatar
You will probably need more in your bottle....how long did you leave it to dwell? do you apply snow foam to dry or wet vehicle?
Robbi Hong Kong is offline   Reply With Quote
Old 30-12-2017, 04:24 PM   #7
mawallace
Allowed to dwell for 5 mins before I rinsed it off. I put on a dry car.
Old 30-12-2017, 04:26 PM   #8
Robbi Hong Kong
Here is the CORRECT way to work out the 4-5% Panel impact ratio;
You need 4 -5% at the panel not in the detergent bottle. You need to fill you detergent bottle full of plain water. Turn the detergent feed on full then discharge the lance into a container - keep going until the detergent bottle is empty of water. Measure the total amount of water collected. Work out 5% of that - this is the amount of auto-foam you need to use in your bottle.
Hope this helps....Bilt Hamber Auto Foam is THE BEST pre-contact wash cleaner available bar none...I use it on every single one of my customers details.
Old 30-12-2017, 04:28 PM   #9
Robbi Hong Kong
Setup
You need to turn your detergent feed on the bottle to MAXIMUM....
Old 30-12-2017, 04:49 PM   #10
mawallace
Think that might be it!
On the setting that I had it 330ml of the bottle was used to fill a 10 litre bucket.
So you get rid of 1l it would fill 30 litres - 4% of tat would be 1.2 litres!
