Old 09-02-2018, 02:44 AM   #1
Chris.91
Clay or chemical decontamination
Hi all,
I have owned a 10 year old Milano Civic since October. It's full of swirls and stone chips. It's only been mini-valeted by a local detailer once in my ownership and rinsed a few times (but I'm hoping to change that!).
I want to get the stone chips to the bonnet and wings repaired in the near future and then have it machine polished by a pro. It looks like there's a few up north too! However, in the short term I want to do as much as I can to protect the car from turning pink. So I'm getting my hands on some wax to protect it from UV.
Before waxing and as the car hasn't been washed properly for a while, I want to get as much dirt off without contact washing (yeah, it's already swirled, but I want to practice the routine and not cause any more damage!) so I'm going to snow foam it. But I've also seen people using traffic film remover, tar remover or fall out remover (are these safe on diamond cut wheels?) along the bottom of the car, arches, etc, either before or after snow foaming. As the car will have quite a bit of contamination on it, which ones should I use, if any?
I suppose I could snow foam, wash, clay bar and then wax. But I've seen that claying can cause micro scratches, so I'm thinking to decontaminate with chemicals instead, but again the micro scratches from claying would be corrected further down when it goes to a pro, so I'm not sure. Also I'm thinking not to hand polish it as I don't want to take off anymore clear coat (even though I assume it'll be a tiny amount), is that being silly - should I buy some polish as well?
Did a bit of research and ended up buying this lot to get me started:
Nisfilk C110.7 Pressure Washer
CleanYourCar Snow Foam Lance
Bilt Hamber Auto Foam
Meguiar's APC
ValetPRO Bilberry Wheel Cleaner
Poorboys Wheel Sealant
Sonax Xtreme Tyre Gel
2x Meguiars Grit Guard and Bucket
3x Premium Lambskin Wash Mitt
Bilt Hamber Auto Shampoo
Bilt Hamber Auto Clay Bar (Soft)
Bouncers Done and Dusted Quick Detailer
Optimum Car Wax
CleanYourCar Huge 'Fluffy' Drying Towel
Nilco Glass Cleaner
Hog Hair Detailing Brushes, Microfibre towels, etc
Any advice welcome.
Chris.91 is offline   Reply With Quote
Old 09-02-2018, 02:56 AM   #2
pug206
You also need a polish, glaze or paint cleanser before waxing.
pug206 is offline   Reply With Quote
Old 09-02-2018, 03:02 AM   #3
Chris.91
Cheers. And of those glaze lasts the least amount of time, correct? Would Lime Prime Lite be a good shout before the wax?
Old 09-02-2018, 03:24 AM   #4
pug206
A glaze just fills in imperfections so wouldn't last long without a wax or sealent on top
Never used lime prime so not sure tbh
Old 09-02-2018, 09:11 AM   #5
petebak
Remember to calculate the correct dilution for your bilt hamber foam, there is a guide in the detailing guide section.
petebak is offline   Reply With Quote
Old 09-02-2018, 09:16 AM   #6
Rían P
Rían P's Avatar
I would reccomend using some type of paint cleanser or polish. It'll definitely lift the paint if it's swirl city. Also, it helps provide a good base for your wax.
'Serious Performance' make a great paint cleanser that'll really clean the paint and lift out any dirt that has bounded to the paint.
Alternatively, Valet Pro's Purple Passion is very good also. Would highly reccomend it.
Never used lime prime lite, though I believe it's along the same lines.
Hope this helps,
Rían P
Rían P is offline   Reply With Quote
Old 09-02-2018, 09:26 AM   #7
Brian1612
Fallout remover and tar/glue remover will rid the paint of some particles of contaminate which aren't heavily engrained into the paint but they won't remove the deeper set stuff. Without claying you won't get rid of them all and your paint will still feel rough after this chemical decon. Claying can cause micro scratches and marring so I'd suggest getting a decent cleansing and filling polish to apply via hand afterwards.
Something like Bilt Hamber Cleanser Polish or Britemax Virtue. Both these contain protection of their own but I would still be topping them with a wax/sealant to help them last longer.
Old 09-02-2018, 11:35 AM   #8
Chris.91
Yep, seems like Poor Boys Black Hole has great reviews for filling swirls etc. Think I may as well get that to hide the swirls until I get it machined...
Yep will do. Heard it’s a bit fiddly the BH foam, but I know it’s not meant to be thick or stay on the longest, but apparently has the most effect!
Hope this helps,
Rían P
Cheers Rian, will look into these. Something to fill the swirls temporarily and clean at the same time would be nice...
Cheers. Will look into those.
Just wondering, my Optimum Car Wax claims up to 5 months durability, but have read people saying around 6-8 weeks is more realistic (car is outside and used daily). Which doesn’t seem like an issue as it’s easy to apply. If that was accurate do you think I’d need to apply the pre-wax cleanser or glaze before waxing again? Or just wash and top up the wax?
Old 09-02-2018, 12:37 PM   #9
BH Cleanser Polish is what you want for this. Cleans and fills in one step. Just top up the OCW when you need to.
BH AUto Foam really isn't fiddly - if you're using in a pump sprayer, just make up a 4% solution, spray it on the car, leave it for 3-4 minutes, rinse it off, ideally at pressure.
If you're using it in a lance, just fill your lance with plain water, then discharge it into a bucket until the bottle is empty, with the feed dial (the +/- on top usually) set to max. Then note the total volume of water in the bucket. Work out 4% of that - that's how much AF you need to add to the bottle before you top it up to the same level as you used for your "test run".
Old 09-02-2018, 12:53 PM   #10
Chris.91
Cheers pal, sounds like good stuff. I'm going to need sponsoring by BH at this rate...
I've heard it's better to use a pump sprayer to apply the BH foam but I want to try out my new toys first so I'll be using the lance . In the guide it says to turn the dial down to the '-' (full foam output) so would that be 'max'?
