Old 15-05-2018, 11:24 AM   #1
sam1970
Any downsides to Carpro Essence?
Hi
I've been reading a lot of threads regarding this product and they all seem to be pretty positive. The product seems to fit my requirements in that used with a finishing/gloss pad it doesn't affect the clear coat, it's easy to apply, gives a great gloss and I can still apply wax (if I really wanted to) on top to satisfy my waxing fetish.
My paint is in good condition with just some light swirls and wash marring. I would much rather fill than correct as long as the fill lasts a respectable amount of time.
I'm just wondering if there are any downsides to this product. It's not a cheap product and I'll be investing in a DPA to apply it so just want to make sure I'm not missing something.
Thanks very much.
sam1970 is offline   Reply With Quote
Old 15-05-2018, 02:25 PM   #2
wayne451
Only thing I'd mention is that it can be a bit of a bugger to squeeze out of the small nozzle but you could cut it lower to enlarge the output area?
wayne451 is offline   Reply With Quote
The Following User Says Thank You to wayne451 For This Useful Post:
sam1970 (15-05-2018)
Old 15-05-2018, 02:29 PM   #3
dchapman88
dchapman88's Avatar
I have found before, if you work it too hard or for too long then it can be a PITA to remove the residue
But it's only happened a small number of times
Normally it's a delight
Old 15-05-2018, 02:36 PM   #4
sam1970
Thank you.
Has anybody applied a second coat of this some months after the initial coat? Can it be applied straight on or does the initial layer have to be removed first?
Old 15-05-2018, 08:34 PM   #5
pxr5
pxr5's Avatar
Coincidentally I was just out in my garage and picked up my bottle of Essence that I only bought earlier this year. Appears it's out of date already, packed Apr 17, expiry Apr 18. Hopefully it will be OK.
Old 15-05-2018, 08:43 PM   #6
dchapman88
dchapman88's Avatar
I've had a chat with CarPro before about the date thing
They said something about having to have dates on the bottles for the purposes of where they produce the stuff
I did ask about if the product will still be the same quality after the 'use by' but never got a reply......
pxr5 (15-05-2018)
Old 15-05-2018, 08:49 PM   #7
sye73
You would like to think CarPro would be able to provide a yes/no answer eh? It's a reasonable question. Maybe they just want people to assume it'll be no good and buy more?
sye73 is offline   Reply With Quote
Old 15-05-2018, 09:00 PM   #8
dchapman88
dchapman88's Avatar
CarPro are a respectable brand, I see no reason for them to be that way
The product speaks for itself and I'm sure people will be buying for that reason
Old 15-05-2018, 11:04 PM   #9
Yellow Dave
Yellow Dave's Avatar
I've tried it by rotary and by hand and not had any issues with application or removal. The gloss is just great.
Only potential issue I could see is the need for it to cure for a few hours before waxing or using a coating over the top.
Old 16-05-2018, 12:14 AM   #10
rlmccarty2000
rlmccarty2000's Avatar
Essence does remove clear coat as it has the same abrasives as their polish Reflect. If you are going to use wax I would use Reflect and not Essence. The SIO2 in Essence does not work the best with waxes. Spraying Reload over Essence works the best if you are not applying a coating over Essence. A second application of Essence would remove the first application due to the abrasives.
rlmccarty2000 is offline   Reply With Quote
