Old 07-07-2018, 07:45 AM   #1
dobbo99
Suggestions on BMW
Im having trouble getting anywhere with an e39 that I recently bought.
I've some of the old Menzerna polishes, PR085 is heaviest and then Meg UC, which have always done the trick on previous cars (which have been newer BMWs to be fair, so not as damaged)
I've bought flexipad orange hex pad, and also flexipad microfibre cutting pads, and some old megs foam pads, but still not making much headway so I'm thinking it's probably a polish thing.
I'm seeing Scholl s20 mentioned everywhere so worth a go? Or a sonax product?
Any suggestions welcomed
dobbo99 is offline   Reply With Quote
Old 07-07-2018, 05:13 PM   #2
mikster
mikster's Avatar
KC h8,02
Old 07-07-2018, 07:21 PM   #3
Timbo84
I use s20 black on my golf which is hard paint like yours.. leaves a lovely finish and has good correction. Definitely worth a try with hex logic green, orange and potentially white pads if it's only light marring. Always start with white and see how you get on
Timbo84 is offline   Reply With Quote
Old 07-07-2018, 10:40 PM   #4
Atkinson91
s20 is a great all rounder, pair it up with the right pads and you can get a perfect cut+finish on most paints with just that one compound
Old 11-07-2018, 11:55 AM   #5
riskypicker
riskypicker's Avatar
DA or Rotary?
I ask as my DAS6 Pro doesnt deal with BMW paint as well as id like.
Old 11-07-2018, 06:11 PM   #6
Tuska
Tuska's Avatar
When used the orange hex it covered the car in small scratches. Unless its a really old paint faided car. I would stick with green hex and try 3m fast cut plus. Failing that try a farecla Gmop. Just my 2pence worth.
Sent from my E6853 using Tapatalk
Tuska is offline   Reply With Quote
Old 13-07-2018, 05:46 PM   #7
dobbo99
I went with Koch Chemie H8. 02
Brilliant
Used orange hexlogic and flexipad cutting microfiber pad on the worse areas, 4 or 5 passes on speed 4, das 6 pro
Even did well with some old 3inch megs polishing pads on the bumpers and tight areas
Really impressed, highly recommended
The Following User Says Thank You to dobbo99 For This Useful Post:
Tuska (15-07-2018)
Old 16-07-2018, 11:55 AM   #8
Vmlopes
Brilliant
What is that combo for the layman?
Vmlopes is offline   Reply With Quote
