Old 13-10-2007, 09:46 PM   #21
Epoch
Epoch's Avatar
Some pics from me
Couple of befores
Recent repray gave an average bonet thickness of around 230 to 240 microns
Out with the 2000 for a test square
Uuummmmm
This test polished out with the desired results so on to the whole bonnet. This shows the finish after 4000 grit
Steve on the Milwakee
After an application of HD Cleanse. It was out with the Rubbish Boy's Original Edition
Then the result
All in all a good first outing
Epoch is offline   Reply With Quote
Old 13-10-2007, 09:48 PM   #22
Epoch
Epoch's Avatar
Originally Posted by BIG BAVARIAN View Post
that's very impressive,should speed up a full paint correction in a breath (no wonder paul (miracle) uses one !!) how does it perform over sharp swage lines,does the backing pad flex enough ?
The pads are the Abrilon system and have about 5mm of foam on them. Thats the only flex but it wasn't so bad. You would have to be cautious.
Old 13-10-2007, 09:51 PM   #23
Phil H
Phil H's Avatar
do you have a close up of the bonnet to show the change in orange peel? I know PD uses this bit of kit i think his has a water feed aswell.
Excellent bit of kit though! and awesome vid
Phil H is offline   Reply With Quote
Old 13-10-2007, 09:54 PM   #24
Epoch
Epoch's Avatar
Only by daylight on my Camera
Before
After
No need for the water feed really as the pads hold a lot of water themselves
Old 13-10-2007, 09:55 PM   #25
megaboost
megaboost's Avatar
Send a message via MSN to megaboost
Get it warmed up, I suspect it could be busy tomorrow
megaboost is offline   Reply With Quote
Old 13-10-2007, 09:56 PM   #26
L200 Steve
Regional Organiser
L200 Steve's Avatar
I guess that we could have gone with a 3m intermediate pad between the dics and the sander if needed.
For a first run out with this bit of kit today I can already see that it has a huge potential in the right hands / on the right job.
You can get a consistent reduction in thickness over a set area with a lot more ease than any polisher that I have used to date.
I do feel that caution should be used though to prevent sand through.
L200 Steve is offline   Reply With Quote
Old 13-10-2007, 09:59 PM   #27
Alex L
Alex L's Avatar
Wanna do a whole car and see how it goes?????
Alex L is offline   Reply With Quote
Old 13-10-2007, 09:59 PM   #28
Phil H
Phil H's Avatar
a nice improvment in orange peel there
Old 13-10-2007, 10:07 PM   #29
L200 Steve
Regional Organiser
L200 Steve's Avatar
That really suprised me Jon - Did I see you wringing out the pads at the end?
I know that we talked about water feed etc before you bought these models, but I realy don't think that you need all the hassles of the extra piping. he spray with Megs #00 solution seemed to do the trick.
The other bit that suprised me was just how 'flat' the paint looked after sanding, almost like we'd painted it with some grey paint. It was pretty easy to see when the surface OP had gone.
Old 13-10-2007, 10:12 PM   #30
ryanuk
ryanuk's Avatar
great vid and great work!
ryanuk is offline   Reply With Quote
