Go Back   Detailing World > General Off Topic > Off Topic Chat
Old 10-09-2008, 11:29 PM   #1
fjs
fjs's Avatar
Ford Focus Mk2 - Position of brake fluid reservoir
On the Focus I own, the brake fluid reservoir is positioned below the overhang of the plastic cover at the rear of the engine bay. There is just enough clearance to remove the reservoir cap, but no way to top it up, other than to use a tube, or squeeze bottle full of brake fluid.
Is this the same on the ST? I have the 1.6 variable valve timing engine.
Has anyone come across the potential top-up/bleeding problem?
fjs is offline   Reply With Quote
Old 11-09-2008, 09:59 AM   #2
fjs
fjs's Avatar
Bumped back up
Old 11-09-2008, 10:31 AM   #3
Dixondmn
Dixondmn's Avatar
yes its the same on the ST. it was the first thing i noticed when i lifted the bonet.
I would guess the scuttle panel is removed or some sort of pump system is used to top it up.....
i'll ask the chaps on the owner forum...
Dixondmn is offline   Reply With Quote
Old 11-09-2008, 11:31 AM   #4
182_Blue
ADMIN
182_Blue's Avatar
you can see it here, not hard to unscrew and top up (not that you should need to top up)
182_Blue is offline   Reply With Quote
The Following User Says Thank You to 182_Blue For This Useful Post:
fjs (12-09-2008)
Old 12-09-2008, 03:41 PM   #5
Dixondmn
Dixondmn's Avatar
ok the official line from the Focus owners club, is that this is a dealer/garage job.
However you could either remove the wipers and the scuttle panel to do it yourself or..... get one of those funnels with a flexi tube on it.
Not great but if your'e carful it should be quite easy.
The Following User Says Thank You to Dixondmn For This Useful Post:
fjs (12-09-2008)
Old 12-09-2008, 04:14 PM   #6
fjs
fjs's Avatar
Thank you - it is useful to know the 'official line'.
Ford does not provide any online guidance on this issue, so the dealer would just wing it. I shall buy a funnel.
Old 12-09-2008, 04:17 PM   #7
fjs
fjs's Avatar
The photograph is actually very useful. It also shows it is near impossible to replace the battery on the ST.
The brake fluid does not need topping up. However, one day it will need replacing.
Old 12-09-2008, 04:30 PM   #8
182_Blue
ADMIN
182_Blue's Avatar
well when graham goode put my AP's on they didn't remove the scuttle panel, they just used a tube
Ps do you think the battery is hard to come out ?
Old 12-09-2008, 04:40 PM   #9
182_Blue
ADMIN
182_Blue's Avatar
ps the scuttle panel is just a bit of plastic held in by a few bolts, it pops off easy and gives access to both battery and fluid reservoir , when we lowered my ST we had it removed in about 2 minsi
Old 12-09-2008, 04:44 PM   #10
ianFRST
Ford Focus RS
ianFRST's Avatar
Send a message via MSN to ianFRST
had my brake fluid changed by ford on the last service, (2nd) cost me 39.99
ianFRST is offline   Reply With Quote
The Following User Says Thank You to ianFRST For This Useful Post:
fjs (12-09-2008)
