Old 19-11-2008, 08:10 AM   #11
BEADING SHINY
DF,
do u know the max dimensions of the Lead Acid battery and do u have any specs for the power supply or charger?
Ill have a look into for u, if u want?
BEADING SHINY is offline   Reply With Quote
Old 19-11-2008, 05:28 PM   #12
s2tommy
Mine didn't work from the box nor did it work after an hour of charging in the car. So i brought one of those adaptors to plug into the wall and for the car charger to plug into that. Left it to charge over night and BINGO!! the thing now works.
Nice write up if we do experience problems
s2tommy is offline   Reply With Quote
Old 19-11-2008, 09:23 PM   #13
Dodo Factory
DW Sponsor
Dodo Factory's Avatar
Originally Posted by BEADING SHINY View Post
Sorry DF didnt mean anything by it.
Not upset mate, helpful info
Dodo Factory is offline   Reply With Quote
Old 19-11-2008, 09:38 PM   #14
drive 'n' shine
Send a message via MSN to drive 'n' shine Send a message via Skype™ to drive 'n' shine
Really is a lucky dip with these it seems, I got a spare one from the same GB as Dom and mine works fine
drive 'n' shine is offline   Reply With Quote
Old 20-11-2008, 12:18 AM   #15
Dodo Factory
DW Sponsor
DF,
I chucked the Pb battery but it was approx 30mmx40mmx70mm from memory. Very small for a Pb. 6v output with 2500mAh capacity. The charger is a 12v output.
Old 20-11-2008, 02:58 PM   #16
BEADING SHINY
That is very small, i can Ni-MH cells to fit in that space just! 3800mAh or 4200mAh, but would have to by pass the charge circuit and use a specific charger. it mite be hard to get hold of Pb batteries that size and capacity although if Briinkmann are selling the torches must still be able to get them.
I've got a contact in the US so ill ask him if he can got hold of them.
Old 20-11-2008, 03:06 PM   #17
PETER @ ECLIPSE
PETER @ ECLIPSE's Avatar
ive contacted brinkmann thinking just that , but for this flashlight they dont do replacement batteries , i highlighted the fact that there is a serious fault with the cell thats in there , but i suppose if their sales are still good then they wont do anything about it .
he mentioned a place called DW thats buying them all then laughed
PETER @ ECLIPSE is offline   Reply With Quote
Old 20-11-2008, 07:23 PM   #18
BEADING SHINY
There must be someone making these batteries somewhere, if that PCB inside the torch is just the charger then there wont be a problem bypassing it and using a external charger and fitting a Ni-MH battery.
Old 21-11-2008, 09:58 AM   #19
BEADING SHINY
Right boys and girls,
I have a lead regarding the Pb battery dims are 43mm x 37mm x 76mm 1800mAh and 43mm x 37mm x 83mm 2000mAh. The capacities are a bit lower than the OEM and size is a tad bigger. I mite be able to get some samples.
I will keep u guys posted.
Old 21-11-2008, 10:10 PM   #20
Dodo Factory
DW Sponsor
Good man
I'll keep you updated re living with my fancy hi-tech battery pack as well.
The Following User Says Thank You to Dodo Factory For This Useful Post:
Silva1 (01-07-2013)
