Old 22-08-2019, 06:25 AM   #1
MAXI-MILAN
MAXI-MILAN's Avatar
LSP sheeting no beading
Looking for new LSP can give excellent slow sheeting zero beading to make drying easier.
MAXI-MILAN is offline   Reply With Quote
Old 22-08-2019, 06:53 AM   #2
A&J
A&J's Avatar
OPT Opti-seal, Menzerna power lock
The Following 2 Users Say Thank You to A&J For This Useful Post:
Loach (25-08-2019), MAXI-MILAN (23-08-2019)
Old 22-08-2019, 09:20 AM   #3
Andy from Sandy
Andy from Sandy's Avatar
At the final rinse stage you need to use an open hose. i.e the water needs to be free flowing and not under pressure.
It is the use of a spray head and pressure that is causing the water to bead up.
Andy from Sandy is offline   Reply With Quote
The Following 3 Users Say Thank You to Andy from Sandy For This Useful Post:
Loach (25-08-2019), MAXI-MILAN (23-08-2019), TeddyRuxpin (03-09-2019)
Old 22-08-2019, 09:31 AM   #4
macca666
macca666's Avatar
I agree with this. I doubt you'll get zero beading OP but I always use an open hose for final rinse as long as you've got decent protection on the car the majority of the water should flow off the car
The Following User Says Thank You to macca666 For This Useful Post:
Old 22-08-2019, 10:22 AM   #5
budgetplan1
budgetplan1's Avatar
'Flood Rinse' does well on coated cars, not much to clean up afterwards:
https://youtu.be/5Oc8cu2N7gw
budgetplan1 is offline   Reply With Quote
The Following 2 Users Say Thank You to budgetplan1 For This Useful Post:
Old 22-08-2019, 02:12 PM   #6
galamaa
I use open hose everytime. For me work better, if I cut hose and made on 30cm long hose with fastening system. One side fastening system and another is pure hose. After that I use electrical leafblower. If you are using drying cloth, then better, that car is wet, because water is like lubrication, not scrub your towel over cure paint you get imperfection.
galamaa is offline   Reply With Quote
The Following User Says Thank You to galamaa For This Useful Post:
Old 22-08-2019, 04:29 PM   #7
Brian1612's Avatar
Obsession Wax Dynasty is a strong sheeting wax.
Old 22-08-2019, 04:30 PM   #8
pt1
pt1's Avatar
Yep, power off then open hose.just used menzerna power lock the other day, lovely product
Sent from my CLT-L09 using Tapatalk
pt1 is offline   Reply With Quote
The Following User Says Thank You to pt1 For This Useful Post:
Old 22-08-2019, 06:38 PM   #9
sm81
Only sidenote is that it beads very well also
sm81 is offline   Reply With Quote
The Following User Says Thank You to sm81 For This Useful Post:
Old 22-08-2019, 08:14 PM   #10
stangalang
king of the flexonian
stangalang's Avatar
If you can get it, echelon cs-1
Ive never used a product that literally doesnt bead, its just a blanket of water over the car until rain or jetwashing stops.
The Following 2 Users Say Thank You to stangalang For This Useful Post:
MAXI-MILAN (23-08-2019), Summit Detailing (24-08-2019)
