Old 12-08-2019, 11:07 AM   #1
Bikeracer
source for Trizact paper
I'm trying to source some Trizact 3000 and 5000 paper in sheet form but can only seem to find it sold in discs.
The sheets are rectangular and approx 3" by 9" to use round a block.
I've got normal wet and dry but want to try the Trizact.
Does anyone know a source for Trizact sheets?
Allan
Bikeracer is offline   Reply With Quote
Old 12-08-2019, 06:25 PM   #2
SamD
I’ve never seen the sheets only discs, you can still use the discs with the block
SamD is offline   Reply With Quote
Old 12-08-2019, 07:04 PM   #3
Zebra
Zebra's Avatar
You might not get Trizact in a sheet but if you want to try a very decent wet and dry sheet, have a look at these:
https://www.cleanyourcar.co.uk/starc...grit-sandpaper
Old 13-08-2019, 10:03 AM   #4
Bikeracer
This is what I'm after, although I have seen some about 3'' by 9"
https://www.amazon.co.uk/30190-Triza.../dp/B00DCMM46G
Allan
Old 08-09-2019, 03:44 PM   #5
waqasr
waqasr's Avatar
Those sheets arnt widely available in the UK from what I saw, i tried getting them too but instead Id say go for meguiars unigrit 3000 grit, super fine and uniform scratch pattern. I didnt like the Starke stuff, I could still see tiny tiny sanding marks after fully removing them, as in like small tiny ripples, never had that problem with the Megs papers.
waqasr is offline   Reply With Quote
The Following User Says Thank You to waqasr For This Useful Post:
Bikeracer (11-09-2019)
Old 08-09-2019, 05:24 PM   #6
91davidw
Jnr Reviewer
91davidw's Avatar
https://www.ebay.co.uk/itm/WET-AND-D...53.m1438.l2649
Get wet n dry on ebay up to 7000 grit in big enough sheets to use on a block.
David
91davidw is offline   Reply With Quote
The Following User Says Thank You to 91davidw For This Useful Post:
Old 11-09-2019, 04:55 PM   #7
Bikeracer
I've got Starke paper but wanted to try the Tryzact "paper". Anyway I received a 3000 and a 6000 disk today which I can use by cutting pieces off to make sanding blocks.
Allan
