Go Back   Detailing World > Lifestyle > The Home and Garden Zone
The Home and Garden Zone All about the Home - including alternative uses for cleaning products ... and all about the Garden
Old 12-04-2021, 09:24 PM   #21
grunty-motor
grunty-motor's Avatar
you have checked that fuel is getting to the carb??? (i.e. not a blockage in the petrol tank or hose)
grunty-motor is offline   Reply With Quote
Old 12-04-2021, 09:34 PM   #22
Rakti
Absolutely! First thing I did when no fuel came out of the bowl drain plug was place a bowl under the fuel pipe and remove it from the carb. Fuel flowed freely.
If Cal is right that the float angle in my 2nd photo is correct, I can only assume that my cleaning of the fuel inlet pipe was unsuccesful and there is still lots of crud blocking it.
Just wondering if maybe I didn't wait long enough for the float chamber to fill up. I thought it would be pretty much instant but maybe it takes a few minutes?
Rakti is offline   Reply With Quote
Old 13-04-2021, 05:35 AM   #23
Caledoniandream
Caledoniandream's Avatar
For £12 it is worth a go, there is definitely a blockage, assuming that the fuel flows freely out of the pipe when you open the fueltap.
The bowl should fill instantly and relatively flow fast for the size of pipe.
So open the fuel without anything attached and it should come out, if not than you have a problem there.
Caledoniandream is offline   Reply With Quote
Old 13-04-2021, 06:45 AM   #24
grunty-motor
As above, just buy a new one - and an inline filter.
The Following User Says Thank You to grunty-motor For This Useful Post:
Rakti (26-04-2021)
Old 15-04-2021, 07:37 PM   #25
Rakti
Fitted a new carb today. Engine fired up first pull. Great £12.59 spend which included a new gasket (filter side) and sealing washer (engine side) that I'd already paid £3.24 for. It also included a new fuel hose that was half the size of mine.
Many thanks for all your help. What a great forum this is.
The Following 6 Users Say Thank You to Rakti For This Useful Post:
Andyblue (15-04-2021), blademansw (17-04-2021), Caledoniandream (15-04-2021), Darlofan (15-04-2021), grunty-motor (15-04-2021), slim_boy_fat (16-04-2021)
Old 15-04-2021, 07:59 PM   #26
That’s great news
Old 16-04-2021, 01:02 PM   #27
bigbrother
bigbrother's Avatar
Originally Posted by bigbrother View Post
Sounds like you have exhausted all fuel issues apart from a new carb, sometimes its better to bite the bullet and buy a new part, [/URL]
Ha told you so, pleased you to my advice LOL
bigbrother is offline   Reply With Quote
Old 16-04-2021, 05:43 PM   #28
Rakti
Yes, well done, you were right. Wish I'd just done it straight away. TBH though, I didn't realise they were that cheap. Thought maybe £45-£50.
Old 19-04-2021, 09:16 AM   #29
kartman
kartman's Avatar
Send a message via Skype™ to kartman
This will be a rubber seal somewhere in the carb being eaten by likely E10 ethanol content in fuel. It may have broke a bit of rubber off and blocked somewhere. Either use super unleaded as this is currently capped to E5 or drain mover and carb off fuel over winter.
kartman is offline   Reply With Quote
The Following User Says Thank You to kartman For This Useful Post:
Rakti (20-04-2021)
Old 19-04-2021, 05:22 PM   #30
Caledoniandream
The other problem E10 has it is hygroscopic (attracts water) and causes aloys to corroded, causing blockage.
The Following 2 Users Say Thank You to Caledoniandream For This Useful Post:
kartman (19-04-2021), Rakti (20-04-2021)
