Go Back   Detailing World > Lifestyle > The Home and Garden Zone
The Home and Garden Zone All about the Home - including alternative uses for cleaning products ... and all about the Garden
Old 12-07-2019, 08:52 PM   #141
Storry
Storry's Avatar
Hi Dan, long time no speak! Just had a quick whiz through the thread and wow! What a turn around!!
Storry is offline   Reply With Quote
Old 12-07-2019, 08:55 PM   #142
Danjc
Danjc's Avatar
Cheers mate hope you are all good. Yeh it’s getting there I have started the last bit behind the garage in the last couple of weeks so I am due to update the thread.
Danjc is offline   Reply With Quote
Old 17-07-2019, 10:21 PM   #143
Danjc
Danjc's Avatar
Over the last few weeks I have cracked on with the last bit which is the decking and summer house.
A couple of tons of type 1 put down then I utilised the old patio slabs and laid them so I had a good solid base.
It’s not pretty and a bit mix and match but spot on for what I need it for, I also ran out of slabs due to giving some away so laid some concrete to fill in the gaps.
I was also faced with a failed slab of concrete that I had been putting off for years so built a retaining wall that I will backfill with concrete.
Frame all built I just need to put some noggins in now.
The Following 2 Users Say Thank You to Danjc For This Useful Post:
rob267 (18-07-2019), SteveTDCi (17-07-2019)
Old 21-07-2019, 10:21 PM   #144
Danjc
Danjc's Avatar
Had to give Waxstock a miss this year, fist time in 5 years ! Getting the garden finished is top of the list at the mo.
Treated both sides of the floor and roof with several coats of preservative, I have something else for the rest.
So finally got to put up the summer house today with much needed help from the good wife. There’s still bits to finish but the majority of it is done.
The Following 3 Users Say Thank You to Danjc For This Useful Post:
johny555ive (22-07-2019), slim_boy_fat (22-07-2019), SteveTDCi (21-07-2019)
Old 30-07-2019, 09:32 PM   #145
Danjc
Danjc's Avatar
Roof felted, side shed door on, underside of the outside canopy/overhang on.
Nearly there with the decking a few more lengths for the fascia and down the sides to deck. Noggins put in as I did the decking so I could make sure they sat under a board and stayed hidden.
As the weather has been crap I have also started painting the inside.
The Following User Says Thank You to Danjc For This Useful Post:
SteveTDCi (03-08-2019)
Old 30-07-2019, 11:43 PM   #146
DrEskimo
DrEskimo's Avatar
Looking great Danjc!
The shed with it's own decking is a great addition.
DrEskimo is offline   Reply With Quote
The Following User Says Thank You to DrEskimo For This Useful Post:
Danjc (30-07-2019)
Old 09-08-2019, 09:41 PM   #147
Danjc
Danjc's Avatar
Some more progress on the summer house. All painted/treated, fascia boards on, flooring down and now it has power.
Decking nearly there but requires a few more coats of oil but having a sufficient dry spell is just not happening as you have all probably noticed ! The boards for the side are all cut and ready to go down but I have some work to do either side so will wait till I have done that so I don’t risk trashing the boards.
After the election had done his thing I fitted some LED strip Lights inside some aluminium extrusion that point at 45 degrees to the ceiling that works really well and controlled via a remote or WiFi and an app on my phone.
Alfieharley1 (10-08-2019), SteveTDCi (09-08-2019)
Old 10-08-2019, 08:47 AM   #148
Serkie
Serkie's Avatar
Enjoying this thread, keep it going - looks great!
Serkie is offline   Reply With Quote
The Following User Says Thank You to Serkie For This Useful Post:
Danjc (10-08-2019)
Old 10-08-2019, 09:56 AM   #149
Alfieharley1
Where is the summer house from looks awesome!
Alfieharley1 is offline   Reply With Quote
Old 10-08-2019, 10:39 AM   #150
Danjc
Danjc's Avatar
There are various companies on the net that do this model but I went straight to the manufacturer and got it slightly cheaper. It is modular so you can have the side shed either on the left or right.
https://www.merciagardenproducts.co.uk/
