Old 07-06-2019, 06:17 PM   #1
renton
Any painters or decorators on here. Need some advise.
Just after some help with a bit of painting Iíve done that looks horrendous and Iím not sure why.
I used Dulux silk emulsion (2 coats) over a most coat and newly plastered walls.
The walls have loads of streaks in them and the paint finish isnít smooth at all but is quite rough ?
Any ideas on what's happening here ?
renton is offline   Reply With Quote
Old 07-06-2019, 07:53 PM   #2
staffordian
staffordian's Avatar
Deleted duplicate post
Can a mod please delete it?
staffordian is offline   Reply With Quote
Old 07-06-2019, 07:56 PM   #3
staffordian
I'm not an expert, just a DIYer with forty odd years of redecorating, but to me, the last shot in particular simply looks like the sort of finish often obtained when using a roller rather than a brush.
Possibly a combination of slightly thick paint and the type of roller used?
The Following User Says Thank You to staffordian For This Useful Post:
renton (08-06-2019)
Old 07-06-2019, 10:23 PM   #4
Pauly.22
Pauly.22's Avatar
We had that when I did a base coat with a roller, I Just painted over it in the end and looks poor. Best thing to do is to sand it down, and use a brush.
Pauly.22 is offline   Reply With Quote
The Following User Says Thank You to Pauly.22 For This Useful Post:
renton (08-06-2019)
Old 08-06-2019, 09:02 AM   #5
Chris9980
Chris9980's Avatar
I do property maintenance and a fair bit of painting, it does look like the pile on the roller is quite long/thick and that would give you that type of effect.
As for the lines, I think as good as any plasterer is you will always get a few uneven areas which really get highlighted by a silk paint.
As others have suggested, I would give it a light sand to get rid of the pile marks, try a short pile roller, works best on a smooth finish wall, as opposed to a texture wall covering like woodchip/anaglypta paper.
Also if youíre choosing to use a silk for easy cleaning, you can use a durable matt emulsion, it would be less shiny and not highlight some of the marks your seeing.
Hope it makes sense and is of use to you
Chris
Chris9980 is offline   Reply With Quote
The Following User Says Thank You to Chris9980 For This Useful Post:
renton (08-06-2019)
Old 08-06-2019, 10:22 AM   #6
renton
Chris
Thanks for the info.
I used a proper short pile roller from Screwfix. Think it was a Harris roller.
If I sand that over will Matt emulsion go over it ok ?
Old 08-06-2019, 10:42 AM   #7
Gas head
i'd certainly go over with matt, silk isn't the most flattering especially in hallway situations cuz the light source is at the ends which highlights any difference in the surface, you could get a pole sander to make sanding easier
Gas head is online now   Reply With Quote
The Following User Says Thank You to Gas head For This Useful Post:
renton (08-06-2019)
Old 08-06-2019, 10:52 AM   #8
Chris9980
Chris9980's Avatar
You wonít have any problems going over the silk with a matt especially as youíre going to sand it first.
Iíve never used a Harris roller, but their brushes arenít too bad so maybe after a sand and a matt finish you might not notice the pile on the paint.
Good luck
The Following 2 Users Say Thank You to Chris9980 For This Useful Post:
ollienoclue (12-06-2019), renton (08-06-2019)
Old 08-06-2019, 03:16 PM   #9
Andy from Sandy
Andy from Sandy's Avatar
On a general decorating note I find it easier to do the glossing first as the emulsion will wipe off the gloss but I find it very difficult to get gloss off emulsion if I stray over the line.
The Following 2 Users Say Thank You to Andy from Sandy For This Useful Post:
Old 08-06-2019, 05:06 PM   #10
HairyMonster
HairyMonster's Avatar
Close up it looks like you've not rolled it out enough.
The new plaster has sucked the moisture out of the paint(dried too quickly)
You should have sanded down after the mist coat and touched up the bare patches.
Sand it all down and try 2 coats of Matt (Dulux Diamond Matt) thinned slightly with water
Let the cutting in dry before rolling.
HairyMonster is offline   Reply With Quote
The Following 2 Users Say Thank You to HairyMonster For This Useful Post:
