Old 11-04-2021, 08:02 PM   #631
c16rkc
c16rkc's Avatar
Nice work Henry, those discs look the business!
Hope the pair fix the vibration issue.
Sent from my SM-N960F using Tapatalk
c16rkc is offline   Reply With Quote
The Following User Says Thank You to c16rkc For This Useful Post:
Henry_b (12-04-2021)
Old 12-04-2021, 01:19 AM   #632
Henry_b
Henry_b's Avatar
Originally Posted by Andyblue View Post
New discs look like they’re proper jobs. Heard good things about the EBC stuff
They're great the EBC pads, seem to have firmed up the pedal no end, and it stops with far more confidence now!
Henry_b is offline   Reply With Quote
The Following User Says Thank You to Henry_b For This Useful Post:
c16rkc (12-04-2021)
Old 12-04-2021, 01:20 AM   #633
Henry_b
Henry_b's Avatar
Thanks Chris they do look cool LOL
c16rkc (12-04-2021)
Old 12-04-2021, 01:22 AM   #634
Henry_b
Henry_b's Avatar
Originally Posted by SunnyBoi View Post
It looks to me the pads have uneven wear, one worn more than the other? I hope you checked the caliper pins if they were binding when you swapped out the rotors
You're correct the one pad was worn more than the other, one was 50% worn while i'd say the other was 80% not ideal..
Weirdly no sticking caliper pistons or guide pins
c16rkc (12-04-2021)
Old 12-04-2021, 01:39 AM   #635
Henry_b
Henry_b's Avatar
Brakes Part 2
I did manage to find a break in the weather yesterday to do the other side, and while it was a simple process this side gave me a few more issues to deal with
So first off after much faffing and frantically searching for my locking wheel nut adaptor the wheel was removed
After some gentle persuasion the caliper bolts were removed, only 2 12mm bolts easy! - after levering the caliper off the carrier I set it aside and started on my caliper carrier
This was a tad fraught, no amount of pushing/pulling on the spanner would make the lower 19mm carrier bolt yield, however a swift smack with a hammer loosened it off
Upon further scrutiny one of my caliper pins were a tad stiffer than i'd of liked
So a quick clean up with some fine wire wool and a fresh coat of grease improved things immensely
At this point it was a case of bolting things back up and squishing the caliper pistons back in, which was dead easy with my caliper tool
During
and done!
I took her out for a good drive and I was amazed at the difference, the brake pedal pulsation has vanished and the steering shudder when braking from high speed has vanished, she now drives/stops like a dream!
The brakes also feel like they have far more bite to them and they don't seem to squeak after hard use like my old mintex pads, a testament to EBC Ultimax 2 pads I suppose!
Well chuffed!
The old disks were well past it on the NS too.
Very deep scouring and a definite warp!
The Following 4 Users Say Thank You to Henry_b For This Useful Post:
c16rkc (12-04-2021), Citromark (12-04-2021), Starbuck88 (12-04-2021), SunnyBoi (12-04-2021)
Old 12-04-2021, 09:36 AM   #636
Starbuck88
Starbuck88's Avatar
Brilliant update Henry Great results, such a serviceable job can make the entire car feel different can't it.
Love the look of the new discs, when mine are shot I think I want to try some J hook discs or ones like yours, I've never owned/had anything other than standard discs.
What's under the cover next to the Jaaaaaaaaaaaag?
The Following 2 Users Say Thank You to Starbuck88 For This Useful Post:
c16rkc (12-04-2021), Henry_b (12-04-2021)
Old 12-04-2021, 05:18 PM   #637
Henry_b
Henry_b's Avatar
Thanks Bud, they do make her feel completely different definitely worth fitting to something quicker like you BMW
As for whats under the cover...
MY2000 Discovery II TD5 with 190k
The Following 3 Users Say Thank You to Henry_b For This Useful Post:
c16rkc (12-04-2021), Ennoch (12-04-2021), Starbuck88 (12-04-2021)
Old 12-04-2021, 09:28 PM   #638
c16rkc
c16rkc's Avatar
You have a Discovery too! Very nice...!
Old 12-04-2021, 10:36 PM   #639
Starbuck88
Starbuck88's Avatar
Your place is like a magicians hat but instead of rabbits it's cars!
The Following User Says Thank You to Starbuck88 For This Useful Post:
Old 12-04-2021, 11:14 PM   #640
Henry_b
Henry_b's Avatar
Thanks she'll go back on the road eventually a fun motor to drive that one.
Just needs some Injector O rings and an MOT
