Old 20-04-2021, 08:56 PM   #661
Henry_b
Henry_b's Avatar
More spannering!!
I've been topping up the coolant for nearly 4yrs now, it doesn't consume too much however its getting annoying and fixing the cause couldn't be easier!
This thing is the throttle body heater and its job in a nutshell is to prevent ice buildup in the ally intake when driving in extreme cold, or through a blizzard and you're intake is sucking in icy cold/damp air
A really simple bit of kit, not really needed in the UK more for the NAS cars however if my car has a feature I like to make sure it works!
Getting to it couldn't be easier, it lives under the throttle body and requires the removal of the throttle body and intake boots, plus a throttle position sensor and a crankcase breather pipe
Here you can see the leak!
4x 8mm bolts for the throttle body and 3x 5.5mm sees the throttle body and heater removed!
And after some careful pulling and twisting the old heater is in the bin!
The throttle body itself needed minimal prep just a quick clean up of the gasket surface was required, for this I used a mild cutting compound and some emery cloth..
And lastly refitment of the new unit which couldn't of been easier, just the reversal of the removal with the benefit that the new unit isn't going to leak everywhere!
I started her up and pressurized the cooling system and we have no leaks!!
The simple things eh!
Henry_b is offline   Reply With Quote
The Following 5 Users Say Thank You to Henry_b For This Useful Post:
Andyblue (21-04-2021), BrummyPete (20-04-2021), c16rkc (20-04-2021), kentphil (20-04-2021), Starbuck88 (21-04-2021)
Old 20-04-2021, 09:10 PM   #662
c16rkc
c16rkc's Avatar
Excellent news!
Nice work Henry.
Sent from my SM-N960F using Tapatalk
c16rkc is offline   Reply With Quote
The Following User Says Thank You to c16rkc For This Useful Post:
Henry_b (20-04-2021)
Old 21-04-2021, 09:18 AM   #663
Starbuck88
Starbuck88's Avatar
Excellent job, hope that cures the coolant loss!
The Following 2 Users Say Thank You to Starbuck88 For This Useful Post:
c16rkc (21-04-2021), Henry_b (10-05-2021)
Old 21-04-2021, 10:45 AM   #664
Excellent job, nice when you get something easy to do and it resolves the issue.
Old one did look well past it...
The Following 2 Users Say Thank You to Andyblue For This Useful Post:
Old 10-05-2021, 10:10 AM   #665
Starbuck88
Starbuck88's Avatar
Any update Henry? Things all good your side?
c16rkc (10-05-2021), Henry_b (10-05-2021)
Old 10-05-2021, 06:34 PM   #666
Henry_b
Henry_b's Avatar
Hiya bud
Nothing to report on the P38 front, she is behaving herself at the moment and plodding along very well
My next venture will probably be HVAC related!
everything well with you
H
The Following 2 Users Say Thank You to Henry_b For This Useful Post:
c16rkc (10-05-2021), Starbuck88 (11-05-2021)
