Old 26-12-2020, 03:02 AM   #1
ammo-mcr
Autobrite snowfoam Lance help how to remove a rounded pipe to I can add quick release
Hello all I have purchased a short trigger gun and the quick release connector needs to be added to the autobrite snowfoam Lance however the part o need to remove is a round pipe with double sided male treads and there’s nothing to grip or hold on to it to turn it anti-clockwise to remove it as seen in the picture below, how do I remove this piece
File Type: jpg 8D0F6932-9E1F-4F0A-A6E5-F9106232C4C7.jpg (12.4 KB, 59 views)
ammo-mcr is offline   Reply With Quote
Old 26-12-2020, 06:50 AM   #2
GeeWhizRS
GeeWhizRS's Avatar
Heat the joint to try and soften the threadlock. Clamp on a pair of mole grip/vice pliers and try and unscrew it. A last resort would be to drill a hole through it so you can put a bar through to give you leverage.
GeeWhizRS is offline   Reply With Quote
The Following User Says Thank You to GeeWhizRS For This Useful Post:
ammo-mcr (27-12-2020)
Old 26-12-2020, 09:17 AM   #3
fatdazza
A decent set of water pump pliers can give you enough leverage to shift them.
Old 28-12-2020, 11:40 PM   #4
Gas head
same as fat dazza, pump pliers, if you heat it too much its a risk for melting the material
Gas head is offline   Reply With Quote
Old 29-12-2020, 10:24 AM   #5
I presume the black nut at the body isn’t part of what you’re trying to remove ? (Does look like it is from the picture)..
If it isn’t, then as has been suggested a set of gripping pliers will assist, but will probably mark / ruin the bit you’re trying to remove...
Old 29-12-2020, 11:15 AM   #6
Steveom2
Good set of mole grips will unscrew that
Steveom2 is offline   Reply With Quote
Old 08-01-2021, 12:55 PM   #7
sidewalkdances
I had this problem - was short on ideas for Christmas so just got a new foam gun
sidewalkdances is offline   Reply With Quote
Old 08-01-2021, 01:16 PM   #8
straight6hatch
I have the exact lance and did the exact thing over xmas.
Honestly, for me, it wasnt hard. A pair of molegrips and a firm grip and it spun off. It didnt even dent the black plastic karcher connector. It was in my cold garage which made the 'locktite' brittle so it kind of snapped. Give it a go!
straight6hatch is offline   Reply With Quote
Old 08-01-2021, 07:04 PM   #9
macmaw
Don’t use vice grips on that, use pump pliers or a small stilson
macmaw is offline   Reply With Quote
