#1 |
T-Cut King (admin)
Detailingworld™Lite Review- Detailguardz Dirtlock
Introduction
Detailguardz Dirt Lock Turbine Wash Bucket insert Priced at $19.99 Uk Ł14.95 https://www.thedetailguardz.com/coll...-bucket-insert The Product What the manufacturer Says - The ONLY bucket insert that uses fluid dynamic principles to filter nearly 100% of your wash water! Patented design utilizes the motion of your hand to engage the DirtLock's turbine induction system. Once you pulse your hand in the bucket, the water is dramatically sped up by the shape of the jet turbine. The Dirt is then forced through hundreds of tapered Venturi funnels and is further sped up, blasting debris to the bottom of the bucket and out of harms way. Only fresh, clean water returns up the side of the dirt-lock through the fresh water troughs. Any small particles that made it through the openings hit the tumbler system and are pushed back down to the bottom of the pail. In short, every time you pump your hand in the bucket the water is automatically filtered and cleaned by the DirtLock. Overview The Insert ![]() ![]() In use Good Fit into Normal Sized Bucket ![]() Finger grips Allow Easy removal and placement ![]() In Situ ![]() Filling up ![]() After Wash ( Car was not that Dirty) ![]() What Was left in the bucket ![]() Results Works Well, Using the finger tabs makes it easy to put into bucket – the legs allow the guard to be fitted correctly and stop it floating in the bucket, dunking the wash media causes any dirt to be forced to the bottom and under the guard – Hope to do some video of this soon Thanks to https://www.thedetailguardz.com/ Detailingworld™ reviewer has followed the Manufacturers Instructions and accepts no responsibility to any circumstances arising from any member using these products or following this test "
Thread Tools | |
Display Modes | |
