Go Back   Detailing World > Lifestyle > The Motoring Zone
The Motoring Zone Just bought a car? Need advice on a car? Want to chat about cars generally? Here is the place to do it.
Old 15-01-2020, 08:49 PM   #31
bidderman1969
bidderman1969's Avatar
Originally Posted by Caledoniandream View Post
Anything after 2015 would probably comply with the ULEZ, but check before you buy.
I think you struggle to find anything more reliable than Kia, Hyundai, Lexus or Toyota.
DPF for most engines is approx 1200 pound, the added cost will be how much work it is, on the the Ford Kuga for example you need to drop the sub-frame, what as a few hours = labour cost.
DPF wear out, people clean them but you cannot refurbish them.
Be careful with cleaned DPF, there are talks to replace the smoke test (MOT) with a different test.
The new test will measure ďparticulate countĒ instead of the current ďopacity measurement ď
This will catch any modifications, worn or damaged DPF in one simple measurement.
Electrical faults are the main reason of breakdowns, and cost the most to put right.
Surely a cleaned DPF will be like new???
bidderman1969 is offline   Reply With Quote
Old 15-01-2020, 09:22 PM   #32
Caledoniandream
Caledoniandream's Avatar
I wish, they maybe improve, but they wear.
A DPF is a disposable part, life expectancy between 70 and 120k
You can cut them open for cleaning (mot failure) so itís a chemical that needs to clean it by either submersion or backflush.
As the filter is so fine itís virtual impossible to clean it 100%.
And like exhausts they donít only corrode from the outside in, the temperature and flow of chemicals, hot gasses etc has a detrimental affect on its inner.
Caledoniandream is offline   Reply With Quote
The Following User Says Thank You to Caledoniandream For This Useful Post:
bidderman1969 (15-01-2020)
Old 15-01-2020, 09:32 PM   #33
SteveTDCi
You need to remove the driveshaft to get the DPF out of a Passat .... cleaning is a waste of time, you can cut them open but you need to prove to the test station why (sometimes a letter will do)
SteveTDCi is offline   Reply With Quote
Old 15-01-2020, 10:26 PM   #34
bidderman1969
Mine must be fubered then
Old 16-01-2020, 05:55 PM   #35
ollienoclue
Blocked DPF?
Nothing a masonry drill bit won't sort...
Some DPFs are designed to be removed and taken for service exchange, I presume they clean them out somehow. I think a genuine Volvo one (including the pikka downpipe and piece of exhaust that houses it) is about £200 so not mental money.
ollienoclue is offline   Reply With Quote
Old 16-01-2020, 07:19 PM   #36
chris182
true, but ive found while researching, that some are just more troublesome than others, maybe wrong, but that's just what i seemed to find
My only experience of DPF warning lights was on a Passat.
Did the exact same journey I did in the Jag (35 miles of M/Way driving 4 times a week) and before I got rid was constantly getting the warning light coming on. Never a problem with the Jag. It was the VW 2.0l 170bhp version.
chris182 is offline   Reply With Quote
The Following User Says Thank You to chris182 For This Useful Post:
bidderman1969 (17-01-2020)
Old 17-01-2020, 03:42 PM   #37
bidderman1969
well, i was thinking of getting my DPF cleaning like this
https://www.copthornemotorcompany.co.uk/dpf-cleaning/
