Old 04-04-2019, 06:18 PM   #1
Rayaan
Rayaan's Avatar
Garage concrete mess
Have had a longstanding issue with the concrete in my garage
Basically it keeps dusting, and is always chalky no matter what. Better in some areas than others but I put paint down on it thinking it'd stop it but nope, the paint just comes off with a very fine layer of concrete dust on it.
Obviously seems to go everywhere too, like car mats, in the house etc
Any idea how to solve this? Im in half minds just to layer it with tarmac or asphalt flooring tbh
Old 04-04-2019, 07:34 PM   #2
wish wash
wish wash's Avatar
Have you tried concrete sealer on it.
Old 04-04-2019, 07:52 PM   #3
ollienoclue
You need to use a concrete sealant before painting. Can you go with that rubberised floor paint instead?
ollienoclue is offline   Reply With Quote
Old 04-04-2019, 09:41 PM   #4
N58amx
That will be surfsce laitance in your concrete.
Grind it off brfore painting and job will be a good en.
Not sure of the size of your floor?
But you could use a sander , or grab a locsl floor layer, with a buffing machine
Will take him all of 10 minutes if he has the right gear
N58amx is offline   Reply With Quote
Old 05-04-2019, 01:31 AM   #5
Chrislazski
https://www.promain.co.uk/floor-pain...oor-paint.html
how about this ^^^
Looks like the concrete doesn't need to be acid etched or sanded when using it
Chrislazski is offline   Reply With Quote
Old 05-04-2019, 08:52 AM   #6
slim_boy_fat
slim_boy_fat's Avatar
how about this ^^^
But it does say "Ensure the surfaces to be painted are clean dry and free from dust, " - which is the OP's problem?
Old 05-04-2019, 04:30 PM   #7
Rayaan
Rayaan's Avatar
The floor is 35m2
The paint actually said to thin down with white spirit for the first coat to seal the concrete and then paint neat for second coat
Problem being it keeps dusting no matter what so do I need to use a dedicated concrete sealer after removing the paint?
Old 05-04-2019, 05:16 PM   #8
shl-kelso
No, you need to remove the weak laitance layer until you are down to solid concrete. To do anything else simply means you will continue to have the finish fail as the weak surface continues to break up/dust. You always get this effect with concrete, my garage floor was poured more than 10 years ago and still has sections affected by laitance. In my case I’ve been putting off dealing with it simply as it means emptying it (or at least half of it) then acid etching/washing to remove the last of the weak layer, only then can I think about epoxy floor coating.
In my house I used liquid (anhydrite) screed and this also had a laitance layer which I removed mechanically (scraping) before it could be tiled, so mechanical abrasion can also be used (as described above by a previous poster) but this can create a lot of mess.
The end result is all down to the prep, and unfortunately there are no short cuts if you want a lasting finish.
shl-kelso is offline   Reply With Quote
Old 06-04-2019, 01:46 PM   #9
Rayaan
Rayaan's Avatar
I agree this is what is putting me off also
There is a lot of it from what I can tell so it seems like i just have to cope with it or put something on top to prevent the dust actually coming up
Old 06-04-2019, 06:27 PM   #10
shl-kelso
Probably best to think about interlocking rubber/PVC floor tiles as these will give a good finish without needing to treat the floor first.
The Following User Says Thank You to shl-kelso For This Useful Post:
Rayaan (08-04-2019)
