Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Rupes
Rupes Our history is composed of achievements, challenges, ideas, and international successes. In 1951 the RUPES 123 Stork is launched and instantly becomes an international hit that sparked the continued evolution of existing machine tools. In 1962 RUPES introduced the new TP/PC drill, the first tool in the world with body in technical polymer instead of a traditional cast metals. The new plastic material reduced tool weight and improved electric insulation, becoming an international standard. Moreover, this material improved the worker safety, since it creates a double insulating protection with low weight and excellent durability. Next RUPES revolutionized the world of sanding by launching the first electric random orbital sander, BR 8 in 1968. To preserve the user’s safety, a dust removal system was integrated in all the RUPES sanders and in 1974 the first electric palm sander was introduced: The LE 7, a machine designed single handed operation. 1985 marked the introduction of new vacuum systems, both centralized and mobile. These systems were aimed at the removal of dust generated in smoothing processes, and developed the RUPES “Energy Car”, the first mobile trolleys equipped with vacuum, designed to be easily moved around the workplace. In the year 2000 RUPES earned another star of excellence for the full assembly line automation of the electric motor manufacturing process. 2008 represented a revolutionary change for orbital polishing. The creation of the LHR 150 with its 10 mm diameter random orbital movement, a larger orbit than had ever been seen before in this application. 2010 Under the brand BigFoot, the bar was set even higher in the world of car finishing and detailing. This new system offered random orbital polishers with 15mm and 21mm orbits, forever changing how technicians would approach the process of polishing and refinishing.
Old 27-11-2017, 12:20 AM   #1
Deje
Rupes 21 Mark II actually weight
What does a Rupes 21 Mark II actually weigh?
5.73 ibs says those pages that use Imperial units, it's about 2.6kg, those who use The metric system specify 2.2kg?
