Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Rupes
Rupes Our history is composed of achievements, challenges, ideas, and international successes. In 1951 the RUPES 123 Stork is launched and instantly becomes an international hit that sparked the continued evolution of existing machine tools. In 1962 RUPES introduced the new TP/PC drill, the first tool in the world with body in technical polymer instead of a traditional cast metals. The new plastic material reduced tool weight and improved electric insulation, becoming an international standard. Moreover, this material improved the worker safety, since it creates a double insulating protection with low weight and excellent durability. Next RUPES revolutionized the world of sanding by launching the first electric random orbital sander, BR 8 in 1968. To preserve the user’s safety, a dust removal system was integrated in all the RUPES sanders and in 1974 the first electric palm sander was introduced: The LE 7, a machine designed single handed operation. 1985 marked the introduction of new vacuum systems, both centralized and mobile. These systems were aimed at the removal of dust generated in smoothing processes, and developed the RUPES “Energy Car”, the first mobile trolleys equipped with vacuum, designed to be easily moved around the workplace. In the year 2000 RUPES earned another star of excellence for the full assembly line automation of the electric motor manufacturing process. 2008 represented a revolutionary change for orbital polishing. The creation of the LHR 150 with its 10 mm diameter random orbital movement, a larger orbit than had ever been seen before in this application. 2010 Under the brand BigFoot, the bar was set even higher in the world of car finishing and detailing. This new system offered random orbital polishers with 15mm and 21mm orbits, forever changing how technicians would approach the process of polishing and refinishing.
Old 21-05-2018, 11:44 AM   #1
Scott_Paterson
Scott_Paterson's Avatar
Thumbs up Pad issues
Guys, I maybe going wrong some where but was using the yellow pad at weekend just past and while in the middle of the bonnet the pad exploded from the very centre and bits of pads went very where.
Any thoughts were I went wrong. I am also using a rupes machine and was on setting 4 .
Scott_Paterson is offline   Reply With Quote
Old 21-05-2018, 11:52 AM   #2
A&J
A&J's Avatar
Did you clean the pad after each panel?
Old 21-05-2018, 12:18 PM   #3
cadmunkey
cadmunkey's Avatar
Ive had the same thing happen once. Probably due to heat build up. How long had you been using it for?
Just out of interest do you ever get any stalling with the machine using the green pads? I just dont seem to be able to get along with them at all at any speed.
cadmunkey is offline   Reply With Quote
Old 21-05-2018, 12:32 PM   #4
Scott_Paterson
Hi, the pad had just been primed and I was on the first half of the bonnet which was the first panel.
Sent from my ONEPLUS A5010 using Tapatalk
Old 21-05-2018, 12:34 PM   #5
Scott_Paterson
Not very long at all, was the first panel and wasn't going to hard either. Maybe just a simple defect or something.
Erm I haven't had much dealing to be honest with all the pads, I normally use a positive drive polisher with cc guys or lake counrty pads
