Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Rupes
Rupes Our history is composed of achievements, challenges, ideas, and international successes. In 1951 the RUPES 123 Stork is launched and instantly becomes an international hit that sparked the continued evolution of existing machine tools. In 1962 RUPES introduced the new TP/PC drill, the first tool in the world with body in technical polymer instead of a traditional cast metals. The new plastic material reduced tool weight and improved electric insulation, becoming an international standard. Moreover, this material improved the worker safety, since it creates a double insulating protection with low weight and excellent durability. Next RUPES revolutionized the world of sanding by launching the first electric random orbital sander, BR 8 in 1968. To preserve the user’s safety, a dust removal system was integrated in all the RUPES sanders and in 1974 the first electric palm sander was introduced: The LE 7, a machine designed single handed operation. 1985 marked the introduction of new vacuum systems, both centralized and mobile. These systems were aimed at the removal of dust generated in smoothing processes, and developed the RUPES “Energy Car”, the first mobile trolleys equipped with vacuum, designed to be easily moved around the workplace. In the year 2000 RUPES earned another star of excellence for the full assembly line automation of the electric motor manufacturing process. 2008 represented a revolutionary change for orbital polishing. The creation of the LHR 150 with its 10 mm diameter random orbital movement, a larger orbit than had ever been seen before in this application. 2010 Under the brand BigFoot, the bar was set even higher in the world of car finishing and detailing. This new system offered random orbital polishers with 15mm and 21mm orbits, forever changing how technicians would approach the process of polishing and refinishing.
Old 24-06-2018, 10:02 PM   #1
cadmunkey
cadmunkey's Avatar
Rupes LHR21ES Mark II
Recently got one of these beauties. Did my entire car over the space of a couple of weeks as I have to work outside and the temps havent been kind. Anyway, the sun was super bright yesterday and I could see slight hologramming on my passenger rear panel.
I used the green pad to cut, and the yellow to polish. Would another go with a white fine polishing pad with a product such as Koch Chemies M2 Anti Hologram Polish work for me, or is it best to stick to Rupes own polishes.
Will just a white pad be able to remove the hologram or will I need to use the yellows again. Its just a small area. Cheers!
After watching one of Forensic detailers videos recently I'm beginning to think I might switch to a single stage product like the Sonax.
cadmunkey is offline   Reply With Quote
Old 24-06-2018, 10:12 PM   #2
mikster
mikster's Avatar
Is it a bmw?
Ive used rupes yellow pads with koch m2 and Prefer it over rupes polishes. That combo should do it!
Old 25-06-2018, 12:47 AM   #3
cadmunkey
cadmunkey's Avatar
Originally Posted by mikster View Post
Is it a bmw?
Yes it’s another beemer. You reckon the white pads will do anything before I attack it with the yellows again?
