Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Rupes
Rupes Our history is composed of achievements, challenges, ideas, and international successes. In 1951 the RUPES 123 Stork is launched and instantly becomes an international hit that sparked the continued evolution of existing machine tools. In 1962 RUPES introduced the new TP/PC drill, the first tool in the world with body in technical polymer instead of a traditional cast metals. The new plastic material reduced tool weight and improved electric insulation, becoming an international standard. Moreover, this material improved the worker safety, since it creates a double insulating protection with low weight and excellent durability. Next RUPES revolutionized the world of sanding by launching the first electric random orbital sander, BR 8 in 1968. To preserve the user’s safety, a dust removal system was integrated in all the RUPES sanders and in 1974 the first electric palm sander was introduced: The LE 7, a machine designed single handed operation. 1985 marked the introduction of new vacuum systems, both centralized and mobile. These systems were aimed at the removal of dust generated in smoothing processes, and developed the RUPES “Energy Car”, the first mobile trolleys equipped with vacuum, designed to be easily moved around the workplace. In the year 2000 RUPES earned another star of excellence for the full assembly line automation of the electric motor manufacturing process. 2008 represented a revolutionary change for orbital polishing. The creation of the LHR 150 with its 10 mm diameter random orbital movement, a larger orbit than had ever been seen before in this application. 2010 Under the brand BigFoot, the bar was set even higher in the world of car finishing and detailing. This new system offered random orbital polishers with 15mm and 21mm orbits, forever changing how technicians would approach the process of polishing and refinishing.
Old 13-10-2018, 07:58 PM   #1
ARTB1400
Rotary pad issue
I ask same question almost month and half when recived new Rupes Rotary Pads but upon today no one from Rupes answer me nor over forums not to my emails so I hope someone here will do.
Upon reciving and inspection I see that central hole is out of centre (photos attached) so I am interested if it will affect performance and balance?
The worst is with 180 mm ones but 135 mm and 160 mm are also out of centre - slightly less but still out.
ARTB1400 is offline   Reply With Quote
Old 13-10-2018, 10:15 PM   #2
lowejackson
lowejackson's Avatar
I would try the pad and see what happens. A DA is very sensitive to pad placement on a backing plate and so would be out of balance but a rotary seems more forgiving
However, I do admire your attention to detail (no pun intended)
Old 13-10-2018, 10:30 PM   #3
ARTB1400
I still hope that someone from Rupes will chime in and offer to replace these pads or allow distributor to send new ones as they are not cheap ones.
For that reason I still not use them.
Also, Rupes is respectability company and I think that things like this must not happen and pass QC and that almost 45 days no one answer to my emails :-(.
Old 13-10-2018, 10:58 PM   #4
lowejackson
If an organisation had not responded within 45 days I would just phone whomever you bought them from or write to them.
Old 14-10-2018, 12:51 PM   #5
ARTB1400
I inform seller first day and they still did not get respind from Rupes. They meet each other at Automechanika Frankfurt and nobody from Rupes gives them any answer about issue.
