Go Back   Detailing World > Lifestyle > The Motoring Zone
The Motoring Zone Just bought a car? Need advice on a car? Want to chat about cars generally? Here is the place to do it.
Old 13-11-2019, 08:33 AM   #11
HEADPHONES
HEADPHONES's Avatar
Costco are doing Castrol Edge fully synthetic 4 litres for £19.18 INCLUDING VAT
Offer ends 24/11/19 but they have a few sales every year and i always manage to buy oil for our cars at these prices.
So cheap I can't see any point buying an unknown
May not be the best but hopefully a decent oil.
Old 13-11-2019, 10:00 AM   #12
Cookeh
The most important thing is that the oil you buy meets the ACEA standards and viscosity required for your engine in the range of ambient temperatures you find yourself driving in.
In most cases the additional cost associated with the more expensive oils is down to their additives. Many of these additives are only useful in specialist applications (i.e. very high loading scenarios, or for worn engines, or engines that have sat for a while). For the majority of daily driven or 'beater' cars these additives will not yield any noticeable difference in performance or engine life as long as the oil life intervals remain within the manufacturer guidelines (or better still within the intervals specified for your individual engine as assessed by oil analysis) and meet the required ACEA and viscosity.
High mileage engines with some wear can benefit from some more expensive oils as they can offer additional protection and help reduce gasket/seal leaks and blow-by, engines that have sat for extend periods can also benefit from one interval or so of a good oil to help clean the sludge and varnish, and engines that frequently undergo very high load can benefit from oils designed to be used in such scenarios too, but this is a minority of cases.
Cookeh is offline   Reply With Quote
Old 13-11-2019, 01:00 PM   #13
SteveTDCi
I always use Shell in the Mini, at work we use Quantum who's oil is made by Fuchs
SteveTDCi is offline   Reply With Quote
The Following User Says Thank You to SteveTDCi For This Useful Post:
Zebra (13-11-2019)
Old 13-11-2019, 07:50 PM   #14
slim_boy_fat
slim_boy_fat's Avatar
ECP on offer atm https://www.eurocarparts.com/p/gulf-...5ltr-521774491
I use HB's Viscol [Rock oils as mentioned above^^] at £15.99 for 4(?) litres, because a) it conforms to BMW's LL04 spec, and b) because I change the oil & filter more often than BMW say is necessary.
slim_boy_fat is online now   Reply With Quote
The Following User Says Thank You to slim_boy_fat For This Useful Post:
spursfan (14-11-2019)
Old 14-11-2019, 09:00 AM   #15
NorthantsPete
NorthantsPete's Avatar
At the end of the day it needs to meet spec.
I was suprised by Amsoil, but its expensive. Long drain adn cooler box temrperatures.
9 times out of 10 though any brand at the right spec will do, and my volvo is very fussy being a tight tolerance diesel (d5), but if it says B5 oil on it, its good to go.
NorthantsPete is offline   Reply With Quote
Old 15-11-2019, 06:53 AM   #16
Carlos Fandango
I've used non major branded oils for years without any problems whatsoever. Last purchase was from eBay (5 litres of fully synthetic 5w40 for approx 17 pounds delivered). Provided the viscosity and specifications are the same as the car manufacturer recommends one should be fine. Far more beneficial would be to change the oil more frequently. Always makes me chuckle when Asda sell their own branded oils at different prices for different makes even though the oil is exactly the incidentally Asda often have cracking good deals on engine oil.
Carlos Fandango is offline   Reply With Quote
Old 15-11-2019, 05:16 PM   #17
Summit Detailing
Summit Detailing's Avatar
I never skimp on oil in the same vein as tyres.
Oil is the lifeblood of the engine and tyres are the only thing connecting you to the road.
Opie oils usually have a great selection but not necessarily the cheapest so worth shopping around. As per a previous poster it is vital that the oil meets the basic ACEA specs and correct weighting's as a minimum requirement for whatever vehicle you drive.
Unless this has changed in the last few years Quantum oil as supplied to VAG dealers is from Castrol - I used to work at Castrol HQ
Cheers,
Chris
The Following 2 Users Say Thank You to Summit Detailing For This Useful Post:
slim_boy_fat (16-11-2019), SteveTDCi (15-11-2019)
Old 15-11-2019, 05:36 PM   #18
The Cueball
The Devil's Advocate
The Cueball's Avatar
I’ve been using a UK company called Westway lubricants for a few years now.
Engine oil (both car and bike)
Fork oil
Brake fluid
I’ve found them to be on par with ‘bigger names’ and great value as well.
**Warning, this post may contain sarcasm and/or banter... it's your decision to get upset about it**
The Cueball is offline   Reply With Quote
Old 15-11-2019, 06:18 PM   #19
SteveTDCi
Cheers,
Chris
It changed around a year ago
Summit Detailing (15-11-2019)
Old 15-11-2019, 06:27 PM   #20
Del-GTi
Del-GTi's Avatar
I used Triple QX from ECP in my diesel Skoda for a few years and didn’t have any problems with it. Obviously I don’t know the long term effects in terms of engine wear but it met the specs I needed for a PD engine, didn’t burn off or have an adverse effect on mpg.
