Old 22-06-2021, 07:28 PM   #1
Breezy
Breezy's Avatar
Spraying / Repairing black exterior door handle
any recommendations on how to sort this?
I just want it back to oem satin black, looks like it might need some filler around the edges but essentially sand, fill prime then a normal satin black paint should give the oem look?
Breezy is offline   Reply With Quote
Old 22-06-2021, 09:35 PM   #2
ridders66
ridders66's Avatar
Upol Plast-X plastic paint aerosol in black. Ignore the fact this is for plastic panels. It will paint your handles leaving the finish exactly as they originally should be. I would lightly rub down with some wet and dry to lose the edges of the chips. Dry fully, mask off, using newspaper to mask as large an area as you can to avoid overspray down the doors.
Panel wipe thoroughly, and mist two or three coats on, leaving to flash off for a few minutes each coat. Allow to dry fully and you will be chuffed to bits with the results.
ridders66 is offline   Reply With Quote
