Old 12-10-2019, 05:15 PM   #1
detailR
detailR's Avatar
Meguiar's 2 Step Restoration Kit
I wasn't sure what section this would belong in, so mods, please move as necessary
The headlights on my car were dull and oxidised.
They'd bothered me for a long time but I'd never had time to do anything with them.
Step in the Meg's 2 Step Kit.
20191012_091713 by Richard Lewin, on Flickr
A simple process.
You get 2 little scotch pads, some cleaning solution and a coating aerosol spray.
Headlights before.
20191012_091205 by Richard Lewin, on Flickr
20191012_091210 by Richard Lewin, on Flickr
With the headlights clean, mask the surrounding area to avoid damaging any paint, rubbers etc.
20191012_091703 by Richard Lewin, on Flickr
Step 1.
Apply around a 10p coin sized amount of the cleaning solution to the scotch pad and work into the light.
I chose to do up-down then left-right motions for an even finish.
20191012_091856 by Richard Lewin, on Flickr
The pad has velcro backing and the box says it works with the Meg's DA system so I gave it a go on a rotary with 3" backing plate.
Speed 1, no pressure. It saved a lot of time and elbow grease.
Aiming for an even - dull finish.
20191012_093540 by Richard Lewin, on Flickr
Now, the instructions say to go straight to Step 2, but I couldn't help using a panel wipe to remove the rest of the cleaning solution.
I also used some masking sheet to protect the panels from over spray.
Step 2.
Start with a light layer of the Headlight Coating, allow to dry for 5-10 minutes, then apply a heavier "wet coat".
20191012_094115 by Richard Lewin, on Flickr
Once dry, you'll have nice clear headlight
Meguiar's say it'll last up to a year, which for the time taken is pretty good in my eyes.
The whole process took me around 20/25 minutes.
The finished result.
20191012_094407 by Richard Lewin, on Flickr
20191012_094411 by Richard Lewin, on Flickr
My lights have a lot of scratches and bits inside where they'd been split and painted in the past, but they're much better
Here's a video of the process too...
https://youtu.be/APYJPxiKwcY
www.detailR.com
Milton Keynes - Buckinghamshire
Ceramic Pro - Auto Finesse - ODK Wax - PVD Approved SunTek Paint Protection Film
Instagram @detailr Facebook @detailR
detailR is offline   Reply With Quote
The Following 6 Users Say Thank You to detailR For This Useful Post:
Compo (12-10-2019), EliteCarCare (15-10-2019), Fentum (31-10-2019), Jue (12-10-2019), RS3 (14-10-2019), Ste T (12-10-2019)
Old 12-10-2019, 07:25 PM   #2
Looks like it’s done a good job. Definitely seem ‘brighter’ and clearer lenses.
detailR (14-10-2019)
Old 14-10-2019, 08:39 AM   #3
detailR
detailR's Avatar
Originally Posted by Ste T View Post
Great results and thank you for taking time to share this, i think i will give my head lights a go, they have slight chemical etching and for £30 whats to loose.
https://amzn.to/2MGWrNM
It's definitely worth a shot.
I picked some up in Halfords while I was getting wiper blades for my wife's car. I think it was about £27 with the trade card.
www.detailR.com
Old 14-10-2019, 09:23 AM   #4
NorthantsPete
NorthantsPete's Avatar
looks ok but i went ahead and got used some Ultimate compound fromt he shed.. works fine.
Next added bsd to protect.
NorthantsPete is offline   Reply With Quote
Old 14-10-2019, 11:22 AM   #5
TeddyRuxpin
TeddyRuxpin's Avatar
You know, BSD doesn’t clearly state that it has UV protection, so it might just yellow quickly. Perhaps it might be a good idea to get some proper protection on there, ideally a clear coat or perhaps a long life sealant with UV protection?
TeddyRuxpin is offline   Reply With Quote
Old 14-10-2019, 12:07 PM   #6
detailR
detailR's Avatar
There's lots of ways of doing your headlights, if you're happy to keep polishing then up every few months, then it's no trouble, and a cheaper solution.
My usual method would be to wet sand, machine polish and apply PPF.
I just wanted to give this a go I used about half the kit sonic inget 2 years of clear lenses out of it, it's good value for money.
www.detailR.com
Old 15-10-2019, 05:04 PM   #7
Christian6984
Christian6984's Avatar
Great work and very common on the Fiesta. Mine was particularly on the top half where the little bug eyed side light is. Trying to keep on top of it as not sure id have the skills to do PPF
The Following User Says Thank You to Christian6984 For This Useful Post:
detailR (15-10-2019)
Old 16-10-2019, 11:03 AM   #8
NorthantsPete
Its not the UV that clouds them but the bacteria build up - anything that repells or antibacterial will work to a degree
anything that makes biological stuff harder to adhere will help.
