Pre-wash stages, Washing, Drying, Clay & 'Quick Detailing' Discuss All your prewash stages- washing, claying, pre rinse , claying and drying
Old 13-10-2019, 06:33 PM   #1
nobbles
Nilfisk blocked with snowfoam lance?
So when the cleanyourcar foam lance is attached it is like it is blocked. I stripped down and cleaned the gauze, no difference, I tried without the gauze no difference.. but when I attach and remove the foam lance to the nilfisk it is really stiff and very difficult to remove - the insert 1/4 turn. It didn’t used to be like that. The normal power wash end attaches and removes easily but not the foam lance. Is there something I am missing?
nobbles is offline   Reply With Quote
Old 13-10-2019, 07:38 PM   #2
GSVHammer
GSVHammer's Avatar
Just had a similar problem with my nilfisk lance. Placing anthing into the main body of the lance was no to bad but removing was hard. I was thinking that the spring in the main part of the lance had stuck or maybe a washer is stopping it releasing. I was going to order a replacement washer set. Last time I used the lance it started spraying water out of the side of the lance as though it had split. I haven't taken it apart yet as I've a couple of spare lances.
Maybe a similar fault to yours.
Old 13-10-2019, 08:49 PM   #3
Ste T
Ste T's Avatar
do your other attachements (offical one) fit ok?
Ste T is offline   Reply With Quote
Old 14-10-2019, 05:10 AM   #4
nobbles
The original spray lance fits ok, a little bit sticky but much better than the the snow foam lance.
Old 14-10-2019, 05:30 AM   #5
AndyQash
AndyQash's Avatar
Not sure if this is relevant, but I always found that if I didn't release the pressure once the waher was turned off the lance was difficult to get off.
AndyQash is online now   Reply With Quote
Old 14-10-2019, 01:32 PM   #6
shl-kelso
I’ve often had problems in the past too getting attachments out of my P150 gun. In the end I tried lubricating the end of the fittings (especially the o-rings) with silicone grease, and that seems to have done the trick - no more sticking attachments for me.
shl-kelso is offline   Reply With Quote
