Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Gtechniq
Gtechniq Gtechniq was founded by quantum physicist Drew Gill in 2001, out of a total dissatisfaction with the performance of paint protection products at the time. Everything from waxes, to new-fangled polymers and PTFE based miracle treatments, nothing on the market offered any meaningful durability, either in looks, or protection. Worse still, he found that most of the products actually performed poorer than the paints they were supposed to protect. From this discontent came a simple idea, ‘To engineer the world’s most beautiful, perfectly finished, smartest and most intelligent surfaces. Surfaces that do much more than simply look great when new.’
Old 01-06-2016, 10:58 AM   #191
Sebinho9
Sebinho9's Avatar
Hey all. Been lurking for a while.
If my car has been Exo'd by a professional detailer (as opposed to a rank amateur like me), what should be my routine for washing it? I've got W4 Citrus Foam, G-Wash, W6, W7, W8, P1 Nanopolish, C2V3 and QD.
I was thinking pre-wash, Gwash, W6/7/8 as necessary, but then I am stuck. Do I use P1 on the paint and then the C2V3 or just the C2V3? Anything after?
For wheels I have C5 Wheel Armour and for glass I have G4 and G6.
My car is new but has done 700 miles since the first wash and Exo protection, so could do with a little spritz to make it shiny again, but does not need a protection stage.
I gather panel wipe is a good option prior to the P1 or C2V3, so may get some of that too.
All advice welcome.
Thanks.
EDIT: I have found out that EXO should be fine as the outer layer for 18 months or so. I will use snow-foam and 2BM to maintain, with QD/C2 if necessary. I will use W6-8 where necessary too. Thanks.
Sebinho9 is offline   Reply With Quote
Old 03-06-2016, 05:55 PM   #192
Sebinho9
Sebinho9's Avatar
That said, what do people apply T1 with? Are applicator pads OK or is it better to use a cloth?
Old 06-06-2016, 02:52 PM   #193
EvolutionDetail
Is I1 Smart Fabric suitable for suede?
EvolutionDetail is offline   Reply With Quote
Old 06-06-2016, 04:58 PM   #194
footfistart
footfistart's Avatar
Yes is the answer. I've used it on my suede seats and works a treat. Just use it as you would with other fabrics.
footfistart is offline   Reply With Quote
Old 06-09-2016, 09:32 AM   #195
sealthedeal
Is there a post somewhere in these 20 pages that focusses on CSL usage ?
sealthedeal is offline   Reply With Quote
Old 06-09-2016, 09:39 AM   #196
K777mk2
K777mk2's Avatar
I use foam pad of the £1.00 for 12 ebay variety, no issue at all, use for a few applications.
K777mk2 is offline   Reply With Quote
Old 06-09-2016, 09:39 AM   #197
gtechrob
Gtechniq UK
gtechrob's Avatar
see this link here for our application instructions that come with CSL
Follow us on Twitter n Facebook Find your nearest Gtech Accredited Detailer and click here to buy Gtech goodies
gtechrob is offline   Reply With Quote
Old 06-09-2016, 09:41 AM   #198
K777mk2
K777mk2's Avatar
16 months on, c1+exo still fine, i just wash and Gtechniq DS.
Wheels with C5 same, still perfect.
The Following User Says Thank You to K777mk2 For This Useful Post:
gtechrob (06-09-2016)
Old 05-03-2017, 06:25 PM   #199
FakeThinkpad
So I'm about to apply my first real coating and opted for the CSL + EXOv3 but have a few questions before jumping in to it. I have watched and read a couple of application instructions but still have a few things I need to clear out.
How long is the curing time of the CSL exactly?
reason I want to know is that I would imagine this will determine how many MFs I use and if the curing time is very short I suppose I need a new MF for every other panel to make sure i don't put something hardened/crystalized on the paint, not to mention the suede cloths I plan on using, will these need to be replaced after each panel?
IE, should I assume to get 8 (folded) wipes out of each MF and 2 uses of each suede cloth?
Also, how does the product bond to paint that has heavy paint chips or road rash?
FakeThinkpad is offline   Reply With Quote
Old 30-06-2017, 01:43 PM   #200
Tim182
My detailer seems to have applied the CSL + EXO v3 in direct sunshine. Now to be fair, they still seem to have done a good job, reduced drying time and it came out spotless. The hydrophobic properties of the coating are there. However, is this application likely to reduce the longetivity?
Tim182 is offline   Reply With Quote
