Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Gtechniq
Gtechniq Gtechniq was founded by quantum physicist Drew Gill in 2001, out of a total dissatisfaction with the performance of paint protection products at the time. Everything from waxes, to new-fangled polymers and PTFE based miracle treatments, nothing on the market offered any meaningful durability, either in looks, or protection. Worse still, he found that most of the products actually performed poorer than the paints they were supposed to protect. From this discontent came a simple idea, ‘To engineer the world’s most beautiful, perfectly finished, smartest and most intelligent surfaces. Surfaces that do much more than simply look great when new.’
Old 25-05-2012, 03:35 PM   #1
037981
I1 on Tiles Works good
I know this might be a car detailing form but I thought I would post up Some things outside of the normal that I have done with Gtechniq I coated my sunglasses with c1 works a treat Also did my mobile phone A couple of days ago I retile my bathroom and clean a couple of Tiles
with ipa and sprayed some i1 on them seems to be working very good I don't know if it has soaked into the surface or if it is just on top of the surface but it definitely works better than the commercial Stuff you buy at the hardware Shop don't know about how long it will last
037981 is offline   Reply With Quote
Old 25-05-2012, 05:05 PM   #2
organisys
organisys's Avatar
Try some G5 on your shower glass too!
organisys is offline   Reply With Quote
Old 25-05-2012, 05:11 PM   #3
rob3rto
rob3rto's Avatar
Same here. Used to use the Lidl W5 nano tech windscreen sealant until it disappeared.
rob3rto is offline   Reply With Quote
Old 25-05-2012, 05:59 PM   #4
CraigQQ
Pass The Sandpaper. . .
CraigQQ's Avatar
I1 works rather well on stone/slate, durability.. I'm sure rob would be able to give you better info on that.
A Born Festooligan
CraigQQ is offline   Reply With Quote
Old 25-05-2012, 06:17 PM   #5
gtechrob
Gtechniq UK
gtechrob's Avatar
i1 will work on any absorbent substrate. durability will depend on wear but on most areas you should get at least 1 year.
Follow us on Twitter n Facebook Find your nearest Gtech Accredited Detailer and click here to buy Gtech goodies
gtechrob is offline   Reply With Quote
The Following User Says Thank You to gtechrob For This Useful Post:
Strothow (25-05-2012)
Old 25-05-2012, 09:32 PM   #6
rob3rto
rob3rto's Avatar
So glazed tiles are out?
Old 25-05-2012, 09:38 PM   #7
Strothow
Strothow's Avatar
Yep, use g5
Strothow is offline   Reply With Quote
