Tools -Machine polishers, Pressure Washers, Detailing Equipment & Microfiber Sponsored by Detailed Clean : – 303 | 3M | Auto Finesse | Bilt Hamber | Blackfire | Black Mamba | Bouncer's | Britemax | California Scents | CarPro | Chemical Guys | Collinite | Crakalicious | Dakota Products | Dodo Juice | G3 Pro | Gtechniq | Koch Chemie | Lake Country | Meguiars | Menzerna | Muc-Off | Nanolex | OPT | Pinnacle | Poorboys World | Rupes | Sam's Detailing | Scholl Concepts | Soft99 | Sonax | Sonus | Stoner | Valet Pro | Victoria Wax | Wolfgang | Zaino | e-Gift Certificates | Trade Accounts | www.DetailedClean.co.uk
Old 28-07-2021, 10:59 AM   #1
Breezy
Breezy's Avatar
Best electric DA for Wet Sanding?
So in previous years the trusty Porter Cable 7424 has been used for wet sanding with the mirka abralon pads and whilst the throw isnt 100% perfect it doest a pretty good job at web sanding.
I've started looking at the Rupes LHR12E but It doesnt look like you can use a 3" backing plate with it so you would also need to invest in a Rupes LHR75E too which will end up being quite pricey and I would rather one tool that does both!
has anyone found a good alternative or ideal solution?
Breezy is offline   Reply With Quote
Old 28-07-2021, 11:14 AM   #2
GeeWhizRS
GeeWhizRS's Avatar
I make a 3" backing plate for the Rupes LHR12E if you are interested.
Info here https://polisherbackingplates.co.uk
GeeWhizRS is offline   Reply With Quote
Old 28-07-2021, 11:33 AM   #3
stangalang
king of the flexonian
stangalang's Avatar
If you are refinishing clear or colour (noy primer in a bodyshop), you want the smallest throw you can, and ideally not a giant counter weight. I avoid normal detailing random orbital machines now at all costs
Old 28-07-2021, 04:55 PM   #4
Andy from Sandy
Andy from Sandy's Avatar
I would think for the job you want windy tools when playing with water.
Old 28-07-2021, 06:23 PM   #5
SuperchargedLlama
SuperchargedLlama's Avatar
Would you mind explaining why? I don't know and it feels like useful knowledge to have.
Find me on YouTube
https://www.youtube.com/superchargedllama
SuperchargedLlama is offline   Reply With Quote
Old 28-07-2021, 08:44 PM   #6
stangalang
stangalang's Avatar
You don't want or require tons of rotational force. If you watch an air fed ro machine, they oscillate a lot with very little spin. A counter weight shunts the backing plate at a much higher rate than needed as you aren't trying to move round a think pad and grind in a liquid.
Most European high end bodyshops use electric machines with extraction and have like a 3mm, 5mm and 7mm machine depending on the surface they are sanding (filler repair, primer, colour/clear)
I haven't looked back since investing in a dedicated machine for refinishing paint. Will include a video I hope it helps as a visual
https://youtu.be/-Q_Az00VkhU
SuperchargedLlama (03-08-2021)
Old 28-07-2021, 09:05 PM   #7
macmaw
Three very good electric machines to consider, which will cover all sizes required.
Rupes LHR12E Duetto for 5”
Rupes LHR75E for 3”
Rupes Bigfoot Nano Ibrid for 1”
macmaw is offline   Reply With Quote
The Following User Says Thank You to macmaw For This Useful Post:
Breezy (29-07-2021)
Old 28-07-2021, 09:06 PM   #8
macmaw
Not at all, there isn’t a lot of water needed or used for wet sanding
Old 29-07-2021, 04:58 PM   #9
Breezy
Breezy's Avatar
Well I have considered air tools but not sure if a 50L compressor will be enough to power something like a mirka air sander? Not that I'll be running a body shop just for small wet sanding or panels here and there
So the Rupes LHR12E Duetto seems like a good choice especially if there is a "3 backing plate for it
Old 03-08-2021, 09:29 AM   #10
Breezy
Breezy's Avatar
Just to throw something else even more expensive into the mix what about the festool rotex sanders like the RO 150 and 90?
they look amazing for polishing wood but would they be suitable for wetsanding too?
if i can get one that goes from 60 grit to 6000 this would be ideal, the right way round of course!
