Adam's Mega Foam
Adam's Mega Foam Shampoo is a must-have for a routine maintenance wash, daily driver detail, or pre-wash before clay bar decontamination or polishing jobs. Mega Foam Car Soap can be used at any time during your washing process, but we recommend using after you've decontaminated after your wheels, tires, engine bay, and exhaust tips. Since this product is pH neutral it will not add or take away protection, meaning repeated use brings no issue of smudging, streaking, or staining. Adam's Mega Foam Shampoo works exceptionally well in a 2-bucket wash method and was designed and formulated for use in the Foam Gun, Foam Cannon, or another foaming accessory. This product paired with our standard car wash pad, a dirt lock or grit guard, and an Ultra Plush Drying Towel will take your detailing experience to the next level.
• Our most concentrated shampoo ever
• pH Neutral, Concentrated formula
• Designed for maximum suds
• 1-2 ounces for
• Juicy Fruit Fragrance
Available here - https://www.prestigecarcareshop.com/collections/new-stock-not-live/products/adams-mega-foam
Adam's Mega Foam was first released as a live testing experience for all of our customers to try… After seeing the uproar of foaming feedback, we've decided to make Mega Foam a Mega Home in our product line and it's here to stay. Mega Foam is our most concentrated shampoo ever released and the most efficient foaming soap for your foam cannon or foam gun.
Mega Foam's heavily concentrated formulation provides the highest amount of suds and foam while avoiding water spots or sunspots. By creating maximum suds, it provides a thick pillow of lubrication that sits between your wash mitt and paint. This ultra-slick foam significantly removes unwanted or left behind dirt or grime. The foam also traps dirt and reduces the chance of the harmful particles from moving from your wheels to your paintwork. When dirt moves from one part of your car to another, it increases the risk of scratching your finish.
Mega Foam Shampoo can be used in your wash bucket, foam gun, or foam cannon and features a high clinging technology to help cleanse the painted surfaces of any impurities or debris.
Suds! Suds! Suds! Anytime this question comes up... Who has the sudsiest soap on the market? - We want you to think of Mega Foam Shampoo. Adam's Product Development Team created this easy to use soap for any detailing enthusiast, whether a weekend warrior or car care expert. For maximum foam potential, pair with the Adam's Foam Cannon or your favorite foam lance, use in full sun or any indoor setting. For optimal car cleaning results, an effective car wash soap must produce thick luxurious suds that target and eliminates contamination for a spot free finish!
Adam's Mega Foam Shampoo is a pH neutral, concentrated blend of lubricants, surfactants, and high-foaming agents to enhance your washing experience. As this product is pH neutral, it will not remove wax, sealants, or degrade a ceramic coating. This product safely removes dirt, debris, pollen, and other contaminants, and will not dry out plastic and rubber. The unique blend of surfactants and polish agents provides a thick layer of suds and foaming action that provides a barrier between your wash pad and your vehicle's finish.
We released this product to better serve our customers request for a high foaming and sudsing soap, without adding protection and remaining pH neutral. This product can be used in full sun and is safe on all surfaces including glass, headlights, plastic, paint, raw aluminum, and matte finishes. This product is different from any other soap on the market as it not only provides a thick, clinging foam to the surface, but also is pH neutral and can be dried completely from the sun during your wash and be rinsed clean without streaks.
It all starts with the value! - With just a few ounces of our concentrated purple gel, simply pour into a wash bucket, foam gun, or even a foam cannon. With very little soap, you get great value from your container
