As above, take the old one off and you'll see which adapter (if any) you need.
IME, they're easier than ever, like garage_dweller mine slide in and clip to secure. Took 30 seconds to change the lot. I nearly laughed when the assistant at Halfords asked if I wanted them died for £8.
I bought some "bosch" blades from ebay last year and they are already knackered. Suspect they where fakes as bosch blades have always lasted a few years for me.
I had the same ones for my Corsa but they do 2 types Universal fit like yours or Direct fit where it comes with the right bracket and found the universal ones sit higher up.
Yeah they can be fiddly on some models. My Twingo is good that you literally push a button on the wiper and they pull off.
Mercedes have an odd thing, the wipes don't fold out away from the windscreen in their resting position. You have to switch the ignition on, put the wipers on and then turn the ignition off whilst they're in the upwards position. Then they fold out and let you swap the wipers over.
I had a terrible set of Bosch blades on my celica. Made a horrendous squeaking noise and didn't last long either, bought from ECP so I'd hope they were genuine.
It's not just you. I despair everytime I change mine and wife's. Why there isn't a universal fitting I'll never know. My rear one twice now I've had to return it as fitting was wrong.
Oh and stupidly last time my drivers one came with protective plastic on the blade, I failed to notice it went to test the wipers and was furious at the streaky awful finish. Went to put old one back on when I realised🙄
bleeding ridiculous when they list more than one type of wiper blade, really thought i was going mad, again, when a simple task should only have taken one minute to do, you start questioning yourself!
keeping this pack now as a reference for future embarrassment
For future ref the Bosch part number ending in U are universal fitment so come with a variety of adapters and never look as 'clean' on the car when fitted. The part number on the new box is the exact fit pack for specific cars.
Picked up some wipers for the Mrs' Fabia recently, and I see what you mean about the variety of adapters! However, on closer inspection, the box lists which adapter is needed for which car, the bits themselves are numbered, and the instruction sheet has different sections for each number too. Despite the many combinations, it was actually really straightforward (although when I said it was "squeeze the button and it'll just slide off" she didn't realise it would _slide_ off and was trying to pull it up. My instructions weren't clear, of course).
Related Threads
Detailing World Forum
5.8M posts
94.2K members
Since 2005
