Old 27-08-2010, 08:10 PM   #1
CHR15_W
CHR15_W's Avatar
MK1 Golf GTI - Engine Detailing
I have a 1990 Golf Cabrio GTI which I have owned for over 11 years. Just over two years ago I had the engine rebuilt with a few mods:
Rebored engine block 1.9
Ported and polished cylinder head
Newman fast road cam
Vernier cam pulley
The block had been painted with some red paint stuff and it's all flaking off! Also the gearbox is on it's way out the usual crunching from first to second.
So this is the plan:
Remove engine
Complete engine & bay detailing
Have gearbox rebuilt professionally
Refit engine
So this is how she looks at the moment.
After stripdown
Engine out
Removing the clutch pressure plate
Then onto engine stand
Engine bay degreased
After a couple of hours the block now looks like this
The block is degreased & metal prep
Just painted in high temp paint
Masking tape off
CHR15_W is offline   Reply With Quote
The Following 12 Users Say Thank You to CHR15_W For This Useful Post:
"SkY" (28-08-2010), 1999grad (28-08-2010), Bustanut (20-07-2013), Car Key (04-05-2012), chris- (03-05-2012), f4rrs (04-11-2010), James Bagguley (06-08-2013), k@tbloke (27-01-2015), Ongoing (05-08-2013), PeterPatch1 (17-09-2013), txero (30-12-2010), Volkan (21-09-2010)
Old 27-08-2010, 09:51 PM   #2
Lemongrab
Lemongrab's Avatar
Awesome work! I wish I had the know-how, the time and the tools to do that to all my cars. What a refresh!
Lemongrab is offline   Reply With Quote
The Following User Says Thank You to Lemongrab For This Useful Post:
CHR15_W (28-08-2010)
Old 27-08-2010, 10:16 PM   #3
CHR15_W
CHR15_W's Avatar
Thanks for the comment!
Some of the parts taken off have been sandblasted then painted in satin black
Close-up of the finish
Radiator cowling completely stripped, painted and reassembled
New warning sticker applied
Radiator fan cleaned and painted, then replacement sticker applied
Starter motor cleaned up, painted and reassembled. Look like new again!
Old 27-08-2010, 10:34 PM   #4
secla
looks like your doing a good job but on a more important note
You have a radiator and carpet in your garage ?
secla is offline   Reply With Quote
The Following User Says Thank You to secla For This Useful Post:
Old 27-08-2010, 10:46 PM   #5
CHR15_W
CHR15_W's Avatar
I have a radiator but no carpet sadly!
Cleaned up some of the aluminum part to remove the oxide, then a couple of light coats of aluminum spray.
Water pump ready to be reassembled cleaned up and painted
Air flow sensor refinished
Old 27-08-2010, 11:15 PM   #6
CHR15_W
CHR15_W's Avatar
Stripped down, cleaned and painted brake servo and linkages
Sandblasted engine mount bracket then sprayed in satin black and new engine mount rubber pressed in
Old 28-08-2010, 01:56 AM   #7
s2x2
Just in case
Make sure you have no sand in the gauze of the rocker header's built in breather.
Ideally you need to drill out the spot welds of the metal plate inside to be able to take out the gauze, burn it with a flame to clean it and reassemble, with fresh tack welds on the cover plate on the inside of the rocker cover.
You don't want sand going around your new engine, or alternatively, buy a new rocker cover.
HTH.
s2x2 is offline   Reply With Quote
The Following User Says Thank You to s2x2 For This Useful Post:
Old 28-08-2010, 02:14 AM   #8
Ian2k
Ian2k's Avatar
looks mint!
Ian2k is offline   Reply With Quote
The Following User Says Thank You to Ian2k For This Useful Post:
Old 28-08-2010, 08:01 AM   #9
acprc
Lovely work, that is going to look superb. I am loving your attention to detail. On a purely practical note would a new water pump be worth the money now?
acprc is offline   Reply With Quote
The Following User Says Thank You to acprc For This Useful Post:
Old 28-08-2010, 08:33 AM   #10
CHR15_W
CHR15_W's Avatar
Thanks for the comments guys. The rocker cover was cleaned up with a wire brush on a high speed drill. I didn't sandblast that part because of the built in breather.
The water pump is only about 12 months old, so just needed cleaning up.
Another update!
Some genuine parts ordered
Engine block waiting for the rebuilt head to be fitted
I bought a Zinc plating and Blackener kit to duplicate the original finish on the bolts and brackets for aesthetic and corrosion resistance.
Here are the yellow zinc parts
The Following User Says Thank You to CHR15_W For This Useful Post:
KevinTheOx (12-01-2011)
