Go Back   Detailing World > Technical > Ask Mike Phillips
Ask Mike Phillips A forum dedicated to questions to Mike Phillips.
Old 11-03-2011, 09:42 PM   #1
Mike Phillips
Detailing Guru
Mike Phillips's Avatar
3- Types of Water Spots - Type I, Type II and Type III
Water Spots are more complex than most people assume because there are different types of water spots. Some water spots are merely mineral deposits on the surface left behind after water with minerals has evaporated off the surface. These deposits can often be washed off the paint using a quality car wash soap.
Sometimes these deposits can also leave an imprint in the paint in the perimeter of the spot and in these cases the imprint must be removed using a compound or paint cleaner as it's a defect in the paint, not simply a deposit on the paint. Some sources of water, be it rain with air-borne pollution mixed-in, or sprinkler water from a city water supply or well water, can have corrosive enough elements in it that it will actually eat into or etch the paint leaving a depression or crater in the paint where the water dwelled or dried.
A Type II water spot can only be removed by leveling the surrounding paint by hand or machine with some type of abrasive compound or paint cleaner.
Type III Water Spots are primarily a stain in the paint which looks like fading where water pooled and then dwelled for some measure of time. This primarily happens to single stage paints which tend to be more porous and thus will absorb water into itself. If Type III Water Spots are limited to only the upper surface of the paint then they can be removed by abrading the paint by hand or machine with a compound or polish.
Before attempting to remove water spots it is important to first diagnose which type of water spot is affecting your car's paint.
Type I Water Spots
These are Mineral Deposits or what people commonly call "Hard Water Spots". It's the minerals in water that people are referring to when they use the word "hard" in the term "Hard Water Spots.
Type I Water Spots are primarily a mineral or dirt deposit laying on the surface of paint. Type I Water Spots can be the results of minerals suspended in city water or well water that are left behind after the water evaporates off the finish. This can happen by washing a car but not drying the water off the paint or if a sprinkler goes off next to the car covering the car with water drop that are not dried off the paint.
Type I Water Spots can also be dirt or pollution particles left behind after water from rain or inclement weather evaporates of the finish. Type I Water Spots can also be Type II Water Spots in that the water can leave both a deposit on the surface and an etching in the finish.
More Hard Water Spots or Mineral Deposits Caused by a Sprinkler
When following the approach of using the least aggressive product to get the job done, the first thing you want to do is to see if you can either wipe the sprinkler water spots off or wash the sprinkler water spots off. Since this car was recently washed and waxed and it's kept inside a garage when not being driven, we're going to try to wipe them off using a spray detailer with a clean, plush microfiber towel.
When removing fresh water spots, use your spray detailer heavy, or wet. Using a product heavy or wet means using extra product, more than you might normally use. The reason for his is you want lots of lubrication on the surface to help prevent any potential scratching or marring of the finish as you're wiping.
Remember, always fold your microfiber towels 4 ways to give you 8 wiping sides with plenty of cushion to spread out the pressure from your hand and wipe the paint gently.
Start out by spreading the spray detailer around to one section and then flip or fold your microfiber towel to a fresh or clean portion to remove the residue and buff to a dry, high shine.
Luck is with us... the paint is safe as the Sprinkler Water Spots did not etching into the paint and using plenty of spray detailer and a clean plush microfiber towel left a scratch-free finish.
Type II Water Spots
Type II Water Spots are actual etchings or craters in the paint because something corrosive in a water source has landed on the paint and was not removed before a portion of the paint was eaten or dissolved by the corrosive substance.
I took this photo myself when I helped Alex Fong from Corvette Forum remove a zillion Type II Water Spots out of the clear coat finish on his Corvette.
Photo Courtesy of MeguiarsOnline.com
Here's a close-up of the same photo, if you look closely you can see the edges are angled downward as this is an actual etching "into" the clear paint.
Type I and Type II Water Spots
In some cases, a water spot can be both a Type I and a Type II, that is you can have Mineral Deposits on the sitting on top of the surface and the water could have been corrosive enough to also etch the paint leaving a crater in the paint where the spot formed.
More Type I and II
These water spots look like they're established water spots, that is, every time it rains, or a sprinkler goes off, the water pools in the same place giving any corrosive substances repeated opportunity to etch into the paint.
Visually, I can tell the paint is likely etched in this instance but I won't know till I get the surface clean. The first step is to wash or wipe the finish, in this instance I'm going to repeat wiping process I used on the Mercedes-Benz with a spray detailer.
After wiping the paint clean, there are water spot imprints remaining in the paint.
Type III Water Spots are spots that look faded or dull and are found primarily found on single stage paints after a water source lands on and then pools on the paint and is usually left to dwell on the surface for some measure of time before it evaporates or is wiped-off the surface.
Modern clear coat paints tend to be harder and impermeable, that is non-porous, so liquids don't penetrated easily and thus stain spots tend to be topical, that is only affect the very upper surface and are easier and safer to remove with a compound or polish.
Older single stage paints tend to be soft and permeable, or porous, it's common for liquids to penetrate into the paint and stain the paint below the surface. Removing stains out of single stage paints can be risky because in order to remove the stains you have to abrade the paint and if the stains penetrated deep then you risk removing too much in an effort to try to remove them completely.
Mike Phillips is offline   Reply With Quote
The Following 16 Users Say Thank You to Mike Phillips For This Useful Post:
Damien89 (09-04-2011), Danno1975 (19-03-2011), dmpoyz (19-03-2011), fethead (25-09-2016), fozzy (22-03-2011), irf@n (17-03-2011), james vti-s (14-08-2011), james_death (21-03-2011), Martin_HDI (23-03-2011), mishy (11-03-2011), Old-scool- m3 (05-06-2011), RCZ (25-03-2011), scratcher (11-03-2011), stonejedi (25-06-2011), Suberman (16-06-2015), TonyH38 (07-02-2014)
Old 18-03-2011, 05:44 PM   #2
Bradley
Bradley's Avatar
What would be the best method you would advise for removal of stuborn water spots from glass?
Bradley is offline   Reply With Quote
The Following User Says Thank You to Bradley For This Useful Post:
gregb (27-03-2011)
Old 27-03-2011, 06:00 PM   #3
30301
30301's Avatar
Could you remove Water spots with machine polishing?
I ask as I have Degreaser deposits on the car,I failed to remove residue and I believe the have etched on paint.
That said, I have not washed the car yet. Thanks
30301 is offline   Reply With Quote
Old 31-03-2011, 11:28 PM   #4
Mike Phillips
Detailing Guru
Originally Posted by Bradley View Post
What would be the best method you would advise for removal of stubborn water spots from glass?
I spent most of my life in Oregon, which is known for rain. Here's the point; if you detail someone's car, that is make the paint all shiny, you can't give it back to the customer with shiny paint but water spotted windows.
In Oregon, because it rains a lot the paint AND glass is often times water spotted. During my time in Oregon I was predominantly a Meguiar's user for detailing cars and as such used a lot of M04 Heavy Cut Cleaner or M49 Oxidation Remover to polish water spots and road grime film off of exterior glass and even inside glass once in a while.
Both of the above products use large size, diminishing abrasives, it's the "chunkiness" of the abrasive that gives it the ability to abrade off water spots and other gunk without scratching glass. It worked for me by hand or machine.
I have a fairly old thread on MOL that discusses this in-depth, it's actually not a thread started by me but answered by me, something about,
Deep Cleaning Glass
Or something like that for a title in the "Hot Topics" forum.
Lots of people try other products and I repeat this all the time but it usually goes unheeded... it's the "chunkiness" of the above two products that make them effective. Another way of saying this would be any abrasive product with tiny or microscopic abrasives, diminishing or otherwise may work, but not as effective as something you can feel between your fingers when you pour a little out.
Cerium Oxide is used to actually abrade glass to remove scuffs and scratches and it will work also but I've never done any side-by-side testing to see if one worked better than the other.
Some people have good luck with Vinegar and Bon-Ami
Some people use steel wool. Some people recommend steel wool.
I never use steel wool and I never recommend steel wool. Steel against glass will scratch glass.
Old 31-03-2011, 11:30 PM   #5
Mike Phillips
Detailing Guru
Yes, you can remove water spots off glass and paint by machine polishing.
The key is to match the right product and pad for the surface you're working on.
(I try to do everything by machine and take my hand out of all processes if and when possible)
