Go Back   Detailing World > Gallery > The International Showroom
The International Showroom The place the International Detailing World Supporters display their work for viewing : This is a subscription section you will need to go to your userCP (top left of the page) and select Paid Subscriptions for more information.
Old 17-03-2012, 12:29 PM   #1
fishbonezken
fishbonezken's Avatar
Headlight Restoration and Coating: BMW 525 by WetShine.Net
Removing old oxidized lacquer and also sanding marks left by previous technician.
Full process:
1) Masked with 2 layers of masking tape followed by 2 layers of duct tape.
2) Machine sand with Ryobi finishing sander using 800 grit, followed by 1000 grit, 1500 and 2000 grit. Plain water used as lube.
3) Tight corners hand sanded using Optimum No Rinse Wash diluted to QD ratio as lube.
4) Compounded with Osren Perfect 40 compound and 3.5" Lake Country twisted wool pad with Makita 9227C @ 1500 rpm
5) Fine compounding with Meguiar's #101 Foam-Cut Compound and 3.5" Lake Country Orange cutting pad with Makita 9227C @ 1500 rpm
6) Polished with Osren Perfect Cut 2.0 and 3.5" Lake Country White polishing pad with Makita 9227C @ 1500 rpm
7) Final polishing with Osren Perfect Cut 2.0 and 3.5" Lake Country White polishing with Dodo Juice Das 6 Dual Action polisher @ speed 5.
8) Remove tape, wipe down surrounding panels and engine bay. Wipe headlights with water.
9) Coat with GTechniq C1 Crystal Lacquer.
Notes: The edges still had some leftover cracking but much reduced. A lower grit number is needed.
Thanks for looking, all comments are appreciated
fishbonezken is offline   Reply With Quote
The Following 5 Users Say Thank You to fishbonezken For This Useful Post:
-Raven- (18-03-2012), AaronGTi (30-07-2012), bmwmadman (17-06-2012), Th3Doctor (20-03-2012), X3 OXE (22-03-2012)
Old 17-03-2012, 05:31 PM   #2
stefstef
stefstef's Avatar
Great work mate
Congrats
The difference is obvious
You result is perfect
stefstef is offline   Reply With Quote
The Following User Says Thank You to stefstef For This Useful Post:
fishbonezken (17-03-2012)
Old 17-03-2012, 07:22 PM   #3
tonyy
tonyy's Avatar
Great work..
tonyy is offline   Reply With Quote
The Following User Says Thank You to tonyy For This Useful Post:
Old 17-03-2012, 07:59 PM   #4
fishbonezken
Thanks guys!
Old 17-03-2012, 08:02 PM   #5
Derekh929
Derekh929's Avatar
Good job looks nice
The Following User Says Thank You to Derekh929 For This Useful Post:
fishbonezken (18-03-2012)
Old 17-03-2012, 09:31 PM   #6
Racer
Racer's Avatar
Send a message via MSN to Racer
Great Turnaround
Racer is offline   Reply With Quote
The Following User Says Thank You to Racer For This Useful Post:
Old 18-03-2012, 04:25 AM   #7
-Raven-
-Raven-'s Avatar
That's a big improvement there! I'm surprised they were so hazy on a car that's not that old!
-Raven- is offline   Reply With Quote
The Following User Says Thank You to -Raven- For This Useful Post:
Old 18-03-2012, 10:55 PM   #8
Miguel Pestana
Great work
Miguel Pestana is offline   Reply With Quote
The Following User Says Thank You to Miguel Pestana For This Useful Post:
fishbonezken (22-03-2012)
Old 19-03-2012, 10:21 PM   #9
Andy Rich
Are they plastic lenses? I have a VW with headlights in a similar condition & was looking to revive them
Andy Rich is offline   Reply With Quote
The Following User Says Thank You to Andy Rich For This Useful Post:
Old 20-03-2012, 10:28 PM   #10
Vossman
Vossman's Avatar
Finishes the car perfectly, great job.
Vossman is offline   Reply With Quote
The Following User Says Thank You to Vossman For This Useful Post:
