Over the last few weeks I've slowly got a spare rear suspension beam ready to go on.
On the 106 & Saxo they suffer from the rear bearings collapsing in the rear trailing arms. The bearings are easy enough to replace but sadly 99% of the time, the worn bearings mark the bearing surface of the beam(commonly reffered to as "pins") and render the beam scrap. its very hard to find good original beams now, but fortunately over the years, I've managed to put 3 or 4 away for rainy days in the roof of my garage
2021-12-10_12-43-32 by Danny Whitworth, on Flickr
So I dragged one down from the loft and basked in its manky looking glory. (the important "pins" had been lathered in grease and covered with doggy doo bags to protect them!)
2021-12-10_12-42-45 by Danny Whitworth, on Flickr
After alot of effort with scrapers, wire brushes, wire wheels on grinders, belt sander , Bilt Hamber Deox Gel etc, I had a completely bare metal beam!
I then coated then end brackets in grey POR-15 and the centre tube in a few coats of Bilt Hamber Electrox.
2021-12-10_12-48-06 by Danny Whitworth, on Flickr
Once the two primers had a full week to fully cure, I then painted the centre tube in Ford Signal Yellow. The beams themselves were the same on all Saxo's and 106's, but disc brake equipped models had the centre tube painted yellow, with the drum braked models being black.
2021-12-10_12-51-06 by Danny Whitworth, on Flickr
Finally, the end brackets were given a few coats of Frosts Extreme Chassis black and the pins had the storage grease cleaned off. Im now ready to start building up the rear end to VTS spec
2021-12-10_12-51-34 by Danny Whitworth, on Flickr
