Please post in our Community Feedback thread for help with the new forum software! If you are having trouble logging in, please Contact Us for assistance.
Thanks for the offer. I'm already running on Eibach Pro springs which I put on 12 months ago.Sweet stuff mate, I have some original springs off my old 172, only covered 30,000 if ur interested?
I see the only advantage of Hammerite is that you can get it in brush form which might make it easier to apply for some projects. Otherwise this VHT paint is far superior in my opinion. Much glossier - like a porcelain finish - and far more chip resistant. I have found Hammerite very prone to chipping.Awesome work
Thanks aswell, will be refreshing the suspension on my clio soon so this is ideal for me
Would you recomend the paint you used on the hubs over say hammerite, or are they quite similar?
Also check out Epoxy Mastic 121 paint from here http://www.rust.co.uk/epoxy-mastic.cfmI see the only advantage of Hammerite is that you can get it in brush form which might make it easier to apply for some projects. Otherwise this VHT paint is far superior in my opinion. Much glossier - like a porcelain finish - and far more chip resistant. I have found Hammerite very prone to chipping.
Having said that, I'm not going to use Hammerite even for parts of the car that I'll need to brush paint - such as the rear beam and lower arms that I doubt I'll get round to replacing. I am going to use POR15 chassis black for this. It's pricey at £20, but apparently very impressive.
I didn't use vinegar on the callipers. They were soaked in Bilt Hambers Deox-C which is safe on seals etc. The degreaser I used was just All Purpose cleaner which won't do any harm either.Did you not have problems soaking the calipers with the seals on? are they ok after going in degreaser and vinegar? I done my carrier in vinegar but not the calipers yet!
Don't forget to use Super ATE GOLD next flush, it makes it easier to see when the change is complete. It's how I change my brake fluids.Thanks for the advice. I'll definitely have a look at the Mastic 121. Not much to report at the moment. I'm waiting a few days before making my big order at Renault for the remaining parts as I might have an option on uprated dampers 'for testing' - although I'm not sure I need them so the deal will need to be very, very good!
However, I have bought the new brake fluid. Not only is this stuff rated highly, it's blue colour makes bleeding easier - keep going until the fluid turns blue!
Thanks, I had that thought as well.Don't forget to use Super ATE GOLD next flush, it makes it easier to see when the change is complete. It's how I change my brake fluids.
kevin
