At work I use the 3m range of compounds after flated or nibbed a panel I go to polish up with either fast cut plus or xl but can never seem to be able to get rid of the marring and scratches that it leaves even following up with there yellow top and pads they don't shift I make sure the pads I use are clean And try different work times with the compound to break it down is there a trick to this compound or is there an alternative to use as a follow up to this step because it is frustrating to see the scratches it leaves behind any help thx:thumb:
