Hi all
As above, is it worth applying g1 to my windscreen it has loads of really tiny stone chips and random light scratches all over it, would I still get the benefits or will these imperfections interfere with the g1?
Give it a good IPA wipe down if you use G4/cerium oxide to remove everything from in the pits & scratches otherwise they will show up worse
Wouldn't apply it to a cracked/bullseye screen if you plan on getting it repaired as the UV bonding adhesive won't stick (the G1 will get in the cracks)
1 - 5 of 5 Posts
